Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 04-06-2013, 01:43 AM
Ibo81 Ibo81 is offline
Default Fast Track C400 - general problem with driver?
Hello,
a few weeks ago I bought C400. It is quite a good interface but I have registered one specific problem with its driver in connection with DAW software, which was mentioned by many users. Always when I disconnect C400 from USB and connect it again, DAW (Cubase) can NOT recognize it again, until I reinstall the driver again! And of course, it a serious problem, when you need to reinstall the driver always when you need to disconnect the interface and connect it again. After reinstallation it works fine, but when I disconnect it, the problem is here... Very annoying and since this problem seems to be general, probably it is a problem of functionless driver... Moreover it sometimes causes freezing of the computer or BSODs.
Any help or comments?
Thanks
Old 04-06-2013, 05:55 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Fast Track C400 - general problem with driver?
Do you reboot between unplugging/plugging? I have one myself and have not experienced this problem, not that that rules out a driver issue or anything. Is the C400 detected in Device Manager when you reconnect it?
Can you post your full system specs or a Sandra report? It helps to know the OS specs to diagnose.
Also, you're using the latest drivers from the AVID website right?
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 04-07-2013, 10:34 AM
yes I reboot often between plugging/unplugging. It is a notebook so I need to have it mobile... So when I reconnect it, everything is OK in Windows, it is recognized, but its not recognized in CUBASE until I reinstall the driver.
The driver is latest for sure
System is icore5 2,5Ghz, 4GB ram, Windows 7 64bit
Thanks for reactions
Old 04-16-2013, 09:03 PM
Emcha_audio's Avatar
Passing this up to the team.
Manny.
Wave-T.com
Old 04-17-2013, 04:44 PM
Originally Posted by Ibo81 View Post
Hello,
Thanks
HI the team would need a few more info about your problem
First would you mind doing a sandra report so we can have more info on your system.
Then can you please let us know what driver # you are using and also if this happens with other daws beside cubase.
Manny.
Wave-T.com
Old 07-11-2013, 02:48 AM
bukbukXiu bukbukXiu is offline
Had the same problem on windows 7, Ableton Live refused to see c400, not after I unplugged it, but randomly, once in a week or so.
On Windows 8, with latest driver from Avid, everything was fine for a while, but yesterday not only Live, but every single application in my system stopped streaming audio via c400. Foobar either showed the message "Unrecoverable playback error: Audio data format not supported by this device" or just played the music, but with no sound.
I reinstalled the driver, everything worked, but now after a couple of minutes after I press "play" in foobar, the music drawns in rattle, then rattle turns into silence, after that once in a while the music plays for a second, unrecorgnizable and distorted. The whole process repeats after restarting the player. I always used 96kHz for the sake of low latency, but never had this symptoms before, my Pc always managed it.
Old 07-22-2013, 07:20 AM
JoelG's Avatar
Have you gone through the Optimization Guides? Specifically this:
  • Open the Start menu. Right-click on Computer and choose Properties.
  • Click on Device Manager in the upper left corner.
  • In the Device Manager window, double-click on Universal Serial Bus Controllers.
  • Double-click on the first USB Root Hub item.
  • Click on the Power Management tab.
  • Uncheck the box that says "Allow the computer to turn off this device to save power." and click OK.
  • Repeat this process for all other USB Root Hub items.
Joel
Jam Space:
Home:
Rig:
Old 07-25-2013, 06:49 AM
Proto-type Proto-type is offline
I had same kind of problem with streaming. Larger buffer size helped me.
New driver 1.1.5 needs more buffer than older ones. (I Don't know why.)
Go to Fast Track C400 Control Panel -> Setup -> and increase the buffer size.
You can read more information from Fast Track C400 User Guide of setting correct buffer size. I tested all kind of things to get this work and last of all I read the manual.
Old 07-27-2013, 05:57 AM
Streaming problem raises its head again. There must be a bug in 1.1.5 driver and Windows 8 X64 compatibility. Larger buffer helped 3 days. Now I can't stream anything With Fast Track C400. First it streams couple of seconds, then sound get metallized and stops. After that metallized sound pops and get silent repeating that. At first look I would say that c400 is broken, but if I downgrade the driver to 1.0.7 there is no problem and I don't need any extra buffer.
I use Belkin pro series usb 2.0 4,8 meter cable. I have tried shorter cable and different usb2 slots. Didn't help. All power savings are off, also usb root hub. A good thin about this new driver is that it works after sleep mode."when it works"
Maybe I have to downgrade and wait for better win8 supported driver.?
I have i5-3350P @ 3.10GHz,
8GB memory + 4GB usb2 stick in ready boost,
Windows 8 x64,
M-Audio Fast Track C400
I use Sonar X2a Studio software.
If you noticed some spelling errors and Finnish accent, I am not a Pro I am Proto.
SiSoftware Sandra
ID
Host Name : KlausPC
Workgroup : WORKGROUP
Computer
Model : HP p6-2485eo 103C_53316J G=D
Serial Number : CZC31*****
Chassis : HP Desktop
Mainboard : FoxConn 2ADA
BIOS : AMI (OEM) 8.15 02/05/2013
Intel vPro : 8.01.20.1336
Total Memory : 8GB DIMM DDR3
Processors
Processor : Intel(R) Core(TM) i5-3350P CPU @ 3.10GHz (4C 3.3GHz, 3.3GHz IMC, 2x 256kB L2, 6MB L3)
Socket/Slot : FC LGA1155
Chipset
Memory Controller : HP Core (Ivy Bridge) DRAM Controller 100MHz, 2x 4GB DIMM DDR3 1.6GHz 128-bit
Memory Module(s)
Memory Module : Micron 8JTF51264AZ-1G6E1 4GB DIMM DDR3 PC3-12800U DDR3-1600 (11-11-11-29 5-40-13-6)
Video System
Monitor/Panel : Dell Computer DELL U2412M
(1920x1200, 24.0")
Monitor/Panel : ONK TX-SR608
(1920x540, 37.9")
Video Adapter : NVIDIA GeForce GT 640 (3CU 144SP SM5.0 1.44GHz, 384kB L2, 3GB 1.6GHz 192-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : NVIDIA GeForce GT 640 (144SP 3C 1.44GHz, 384kB L2, 3GB 1.6GHz 192-bit)
Compute Shader Processor : NVIDIA GeForce GT 640 (144SP 3C 1.44GHz, 384kB L2, 3GB 1.6GHz 192-bit)
CUDA GP Processor : NVIDIA GeForce GT 640 (144SP 3C 1.44GHz, 384kB L2, 3GB 1.6GHz 192-bit)
Storage Devices
Seagate ST2000DM001-1CH164 (2TB, SATA600, 3.5", 7200rpm) : 2TB (C:) (D:)
Kingston DT Mini Slim (4GB, USB2) : 4GB (G:)
Multiple Card Reader (USB2) : N/A (F:)
hp CDDVDW SH-216BB (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:)
Logical Storage Devices
OS (C:) : 2TB (NTFS) @ Seagate ST2000DM001-1CH164 (2TB, SATA600, 3.5", 7200rpm)
Recovery Image (D:) : 13GB (NTFS) @ Seagate ST2000DM001-1CH164 (2TB, SATA600, 3.5", 7200rpm)
Removable Drive (G:) : 4GB (FAT32) @ Kingston DT Mini Slim (4GB, USB2)
Windows RE tools : 1023MB (NTFS)
Removable Drive (F:) : N/A @ Multiple Card Reader (USB2)
Optical Drive (E:) : N/A @ hp CDDVDW SH-216BB (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : HP H61 LPC Controller
LPC Legacy Controller 1 : T2 87-72
Audio Device : HP Cougar Point High Definition Audio Controller
Audio Device : MSI GF116 High Definition Audio Controller
Audio Codec : nVidia 0015
Disk Controller : HP Cougar Point 6 port SATA AHCI Controller
USB Controller 1 : HP Cougar Point USB Enhanced Host Controller #2
USB Controller 2 : HP Cougar Point USB Enhanced Host Controller #1
USB Controller 3 : HP TUSB73x0 SuperSpeed USB 3.0 xHCI Host Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : HP ePrint (600x600, Parallel, Colour)
Printer : Canon MP280 series Printer XPS (USB, Colour)
Printer : Canon MP280 series Printer (USB, Colour)
Scanners and Cameras
Scanner : WIA Canon MP280 ser (Scanner, USB)
Peripherals
Media Player : Kingston DT Mini Slim (3.73GB)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 1Gbps)
Wireless Adapter : Ralink RT5390R 802.11bgn Wi-Fi Adapter
Operating System
Windows System : Microsoft Windows 8 Home 6.02.9200
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Old 08-18-2013, 10:19 PM
Older driver works.
When do we get new Win8 driver to Fast Track C400?
Any comments from Avid?
Audio Configuration Problem - Fast Track C400 + Studio one 2.6 joaocavanus FireWire & USB Audio Interfaces (Win) 1 03-13-2014 05:16 AM
Problem with M-Audio Fast Track C400 Ohio21 FireWire & USB Audio Interfaces (Win) 2 08-19-2013 12:56 AM
Keystation 61es MIDI problem, Pro Tools SE, Fast Track C400 KidA8787 FireWire & USB Audio Interfaces (Win) 0 07-11-2013 12:56 PM
Is the fast track c400 asio driver compatible with pro tools 10? Terran2012 Windows 2 10-05-2012 08:35 AM
Fast Track c400 Suddenly Clear Pro Tools M-Powered (Win) 3 10-29-2011 02:17 PM
