Nehalem Video Choppy On Second Monitor
UPDATE: See this thread...
http://duc.digidesign.com/showthread.php?t=234720 (Thanks, ddwhitney, for pointing this out.) We're building a new PT8 HD3 system on a new Mac Pro (Nehalem) 2.26GHz 8-core, 16GB RAM, stock video card (NVIDIA GeForce GT 120 512MB) option. HD cards are installed in the Mac; no PCIe expansion. Two identical Apple Cinema HD 23-inch displays (DVI), one on the Mini DisplayPort via adapter. Any video playback is perfect until we move it to the second monitor, or if the Pro Tools window is moved to the second monitor, video playback suffers when moved to the first monitor. Frame sizes and codec don't seem to make a difference. Even a 640x480 Photo-JPEG QuickTime will not play smoothly on the second display with a Pro Tools mix/edit window open on the first. By contrast Avid DNX at 1080p plays perfectly as long as its on the same desktop/display as the Pro Tools window. No windows overlapping desktop boundaries; checked that. Anyone else with a similar build or a solution?
DM Last edited by David McRell; 08-31-2009 at 07:29 AM. Reason: Redirect to similar thread |
Re: Nehalem Video Choppy On Second Monitor
Do you have your video file on the same drives as your audio? If yes, try putting the video file on your OS drive.
If no, I'm not sure. |
There seems to be a work around in this thread if the problem is the same...
Digidesign 003R+PT 2020.12.0, Gigabyte GA-Z97X, CPU INTEL i7-4790 4.0Ghz, CORSAIR DOMINATOR 16GB; ATI Radeon™ HD 5450 PCIe Multiple WD Caviar Black 2Tb Spinner Drives; 1 PPA 80GB 1394 Firewire Oxford 911 PYRO PCI64R2 3 Port Firewire Card (PCIe) Antec 300 case. PSU 600W, Windows 10 Home. |
Video Choppy After Waves Plugins Added | tcstx | Pro Tools 9 | 7 | 02-27-2011 10:27 PM |
Choppy Windows XP Pro SP3 w/ Choppy Protools 8.0.0???-Sandra Included | cornhead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-15-2010 06:51 PM |
Video Playback running choppy | amac84 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-18-2009 01:30 PM |
Mac Pro Nehalem / Pro Tools 8 / movie window plays out of sync on second monitor | monkeyp | Pro Tools TDM Systems (Mac) | 1 | 04-27-2009 02:32 PM |
Choppy video / playback | jdissonant | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-27-2007 04:36 PM |
