Old 03-26-2014, 12:58 PM
graveleye's Avatar
graveleye graveleye is offline
Default buss sends moving when fader moves.
Obviously a setting somewhere has changed, because now my buss sends won't stay where I set them. Soon as I move a fader then the buss level moves too. If I move one of the other send levels, they all change too. This is on a grouped set of drum tracks. How do I decouple the buss send levels from the faders? I can click the group "off" and they will work independently, but that isn't how I like to work and it used to not be that way. I've pored over the settings and can't find the right one. Can someone help me find the setting to make them operate independently again? Thanks...
GIGABYTE X58A-UD3R, INTEL CORE i7 960, NVIDIA GEFORCE 8400GS, WIN 7, MOTU 896mk3 HYBRID, PT 10.3.2
Old 03-26-2014, 02:54 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: buss sends moving when fader moves.
Hi.
Must be in the group attributes? go to group / modify and check globals and attributes and see if you have selected sends to be included in the groups
chris
Producer, Engineer,
www.ukmastering.com
Old 03-28-2014, 07:44 AM
graveleye's Avatar
hmm, yes I looked there but didn't find it. I'll have another look. Might have overlooked it. Thanks.
Cannot Undo Fader moves in pro tools HD 9 ARylands macOS 1 03-15-2012 11:17 AM
Fader moves not included in undo cue? Dopamine Pro Tools TDM Systems (Mac) 2 04-30-2010 05:39 PM
Final Cut fader moves Roger Stauss Post - Surround - Video 6 04-14-2009 07:16 AM
Editing without moving automation moves Ty Ford Tips & Tricks 9 05-27-2006 10:09 PM
01v...Does Protools respond to it's fader moves? inimitable_ingress 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-12-2002 12:40 AM
