Re: Use of busses/plugins
I like to use subgrouping when I'm layering up a sound. Say I have a synth pad part and to get what I want I have 3 or 4 individual synth pads all playing the same part from 3 or 4 different VI's or even the same VI 4 times or whatever, I will sub those to an aux for mixing because I treat them as one massive sound so want to process that way. Of course I can also tweak the individual components of each of the sounds in the layer. To me that's no different than tweaking an oscillator in a multi oscillator synth.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Everything else goes straight to the 2-track (or 5.1-track).
That is really the only logical reason to use aux groups, sound-wise....
If you don't bus anything out then how do you know if the master fader is clipping since it's pre fader? Also the "In The Box" Series on YouTube shows buses everywhere.
Macbook Pro Mac OS 10.10.3 Mbox 2, Pro Tools 11 Last edited by bryced87; 02-05-2014 at 07:46 PM. Reason: spelling |
Does anyone know??
Macbook Pro Mac OS 10.10.3 Mbox 2, Pro Tools 11 |
#16
Test it yourself. (caution, have your monitoring volume at lowest level and headphones unplugged!) Create a track with signal generator at -20dB. Duplicate it to 50 tracks or so, then click the ALL group to raise the volume of all tracks at once. You should hear severe distortion. Now bring in the master fader and it clearly shows the clipping. Then lower the faders little by little until the distortion goes away. And at the same time, master fader drops from the red.
#17
It's post fader? Then I apologize as I read it wasn't
#18
Personally I use aux busses all the time. The only thing I normally don't send to a buss is the lead vocals and bass guitar. I usually have 3 busses (aside from reverb/delay busses), drums, instruments, background vocals. Sometimes I'll add the bass to the instruments, but very rarely.
My reasoning is this. I get each track to sound like it should in the mix (not necessarily soloed, but it's place with everything else as much as possible) using EQ/compression/whatever else it takes. Then I can go though and make subtle tweaks in the busses to give every group a little more space/separation. For example compress the BGV's a little more to keep them from over riding the lead vocals. Sometimes EQ some low mids out and add some highs to give them some air. I also send the buss mix of drums and BGV's to my reverb's instead of individual tracks. This IMO gives a better feeling of the drums being in the same room. Especially since I tend to use a compressor that I can do parallel compression with. Also if the overall mix is too bright/dull I find it better to fix that in whichever group is lacking rather than just boosting/cutting the highs of everything. Anyways. Just some thoughts on why you can use busses if you like.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
#19
does adding busses really degrade the quality? Where is the information that says this?
#20
No, it does not. Using sub mixes requires a different workflow. It is a valid viewpoint to believe that routing directly to the master mix makes for a better sound. If the person mixing believes it is better, it is better and they will mix better.
Recording through busses and plugins | lukeyy | macOS | 1 | 04-16-2013 09:05 AM |
More Busses? | weezamiah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-07-2012 09:24 PM |
LCR aux busses and plugins | Maskeeper | Post - Surround - Video | 1 | 03-09-2012 03:21 PM |
More Busses in PT LE | RuffinMedia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 08-20-2010 05:10 PM |
"Correct" way to use plugins, busses, sends etc..? | George B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-06-2004 11:50 PM |
