Old 11-13-2012, 08:06 AM
ReynaldoPena ReynaldoPena is offline
Thumbs up External Hard Drive 7200 rpm 1-2TBs
Okay guys I am Rolling!!
I don't even know how to install the external to be the driver for my recordings on Pro Tools and FL studio, or if I will end up using the external hard drive as a back up and end up using the internal Hard drive. any tips, hints and recommendations?
Darryl said stay away from drives that say "green": but
http://www.amazon.com/Fantom-GreenDr...NTOM+HARDDRIVE
Take care brush your hair,
Rey
https://r-e-y.com/
macOS Ventura
Pro Tools 2022
iMac (Retina 5K. 27-Inch, 2020)
Processor 3.6 GHz 10-Core Intel Core i9
3.6 GHz Dual-Intel Core i7
16GB ram
AMD Radeon Pro 5700 8GB
Shure SM7B Mic
Pro Tools | Carbon
Komplete Kontrol M32
AKAI Mpk3 Mini
KALI Lp 6 (2)
Old 11-13-2012, 11:09 AM
Default Re: External Hard Drive 7200 rpm 1-2TBs
44 views and edited = nothing
Rey
https://r-e-y.com/
macOS Ventura
Pro Tools 2022
16GB ram
Shure SM7B Mic
Pro Tools | Carbon
AKAI Mpk3 Mini
KALI Lp 6 (2)
Old 11-13-2012, 04:51 PM
That green drive is fine for backups, just don't plan on recording to it. Using a second internal 7200 rpm drive is the best route(cheapest cost and best performance). Many of us use a 3rd drive for sample libraries(if the VI allows you to specify where the samples are stored). For instance, I have ezdrummer and SD2. ezdrummer forces me to install everything to the C: drive, but SD2 allows me to store all the sounds to my samples drive, taking the strain off both the system drive, AND the recording drive Giving you tips is impossible without knowing the details of your system. If its a desktop computer, add internal drives. Some laptops allow you to add another internal, or to swap the optical drive for a second internal drive(external optical drives are fine). Remember, the rule is; use a separate hard drive for recording(it doesn't have to be external).
Old 11-14-2012, 09:07 AM
Weird Audio Weird Audio is offline
The reply above is great . You should take that bit of advice .
Do not use external drives if at all possible.
Keep Pro Tools on its own drive and keep your audio on another , internally if at all possible. . Always save as before save to , or your external will become your write drive . I learned this lesson just this week though a lot of slow performance frustration . In fact unplug your external until you need it just in case
If you save your mix at the end of the day to your external with a newer name or update . When you load that session you are loading playing it and recording it to and from your external drive . Because you didn't save it to your PT drive
External drives are slow . Use external for save backup files not playback files
Do you have to have a 7200 rpm hard drive to run Pro Tools 10? [email protected] Pro Tools 10 24 10-26-2018 12:48 PM
Is this 7200 rpm external hard drive ReynaldoPena Windows 1 11-20-2012 07:54 AM
2.5" 7200 hard drive ThaRhythm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-07-2010 11:54 AM
FW Hard Drive Help? 7200 Fantom drive not working 72reissue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-10-2005 02:28 PM
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be Fucius General Discussion 4 03-19-2002 11:26 PM
