Old 02-14-2012, 12:33 PM
rickwhite rickwhite is offline
Question Playback Gets Garbled half way through
New to this forum, but just bought 9 to do CDs on hypnosis tapes.
I recorded about 20 minutes of stuff, and when playing back it sounded great for the first 10 minutes, and then vocal and music started sounding all scratchy.
Nothing was changed during the recording.., all levels stayed the same.
I tried re-recording several times, and each time it was pretty much the same .
Any ideas on how to remedy this situation?
Private email is fine
Thanks,
Rick White,
[email protected]
Old 02-14-2012, 01:11 PM
Craig F Craig F is offline
Default Re: Playback Gets Garbled half way through
computer?
OS?
audio interface?
Thank you,
Craig
Old 02-14-2012, 01:45 PM
HP laptop Pavilion G7
Windows 7 Pro
M-Audio Fast Track
Old 02-14-2012, 04:52 PM
zedhed's Avatar
zedhed zedhed is offline
Could be a hard drive problem but to get a better understanding it would be best to post a Sandra Report;
Use SiSoftware's Sandra Lite application to generate a full system profile:
www.sisoftware.co.uk
Under SiSoftware Sandra, click on "Download & Buy" to download the free Sandra Lite version or purchase other versions. After installing Sandra, click on the 'Hardware' tab and run the 'Computer Overview', then copy and paste into your post here on the DUC.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 02-14-2012, 05:51 PM
RegenerationMix RegenerationMix is offline
are you recording to an second or external drive and not the system drive?
Chris
http://www.youtube.com/user/RegenerationMix
http://soundcloud.com/regenerationmix
http://twitter.com/regenerationmix
MacBook Pro, 2.4GHZ, 16GB, Intel Core i7, Mac OS 10.9.1 128 SSD internal HD, 750 GB Internal HD, Pro Tools 10.3.8, Digidesign 003r, Waves 8.0, Final Cut Pro 7
Old 02-16-2012, 09:09 AM
This is a brand new computer.., don't see how it could be a hard drive problem,
And yes, I am recording directly to the system hard drive.., and it is quite large and this is not making a dent in it.
Interestingly, I played it back again yesterday and it was playing clearly.., for a while. And then it again reverted to the raspy voice (not only my voice, but the music in the background).
Rick
Old 02-16-2012, 12:04 PM
spenner spenner is offline
Rick
Just because the computer is brand new does not mean that the HDD is good for recording with PT. For example, recording to a 5400 RPM system drive could cause problems. 7200 RPM or higher is recommended, especially if you are recording to the system drive, which is not recommended. A Sis report confirms or rules out component red flags.
Old 02-16-2012, 06:41 PM
zedhed's Avatar
That's most likely your problem. The size of the system drive is irrelevant, you definitely need to record to separate drive if you want PT to perform properly.
As you can see, mentioning a hard drive problem doesn't necessarily mean there's a problem with your hard drives mechanics although as pointed out slower spinning HDD's are not recommended for Pro Tools.
A Sandra Report shows any other potential problems too, which is why it's best to provide one to get the most help.
HD 96I/O
Old 02-17-2012, 07:46 AM
Here is Sandra. It appears the Seagate is 7400 rpm. SO, you think it would work better there?
SiSoftware Sandra
ID
Host Name : RickWhite-HP
Workgroup : WORKGROUP
Computer
Model : HP Pavilion g7 Notebook PC 103C_5335KV G=N L=CON B=HP S=PAV X=Null
Serial Number : 5CD1450HZ3
Chassis : HP Notebook
Mainboard : HP 1671
Serial Number : PBVEK014J11P2G
BIOS : HP F.33 08/30/2011
Intel vPro : 7.01.03.1053
Total Memory : 8GB DDR3 SO-DIMM
Processors
Processor : Intel(R) Core(TM) i3-2330M CPU @ 2.20GHz (2C 4T 2.2GHz/2.2GHz, 2.2GHz IMC, 2x 256kB L2, 3MB L3)
Chipset
Memory Controller : HP Core (Sandy Bridge) Mobile DRAM Controller 100MHz FSB, 2x 4GB DDR3 SO-DIMM 2x 667MHz (1.33GHz), Integrated Graphics
Memory Module(s)
Memory Module : A-Data AD73I1C1674EV 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5)
Memory Module : Kingston 99U5428-042A00G 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Video Adapter : Intel(R) HD Graphics Family (12 SM4.1 650MHz/1.1GHz, 64MB DDR3 1.33GHz 128-bit, Integrated Graphics)
Graphics Processor
Compute Shader Processor : Intel(R) HD Graphics Family (12SP 650MHz/1.1GHz, 64MB DDR3 1.33GHz 128-bit, Integrated Graphics)
Storage Devices
SAMSUNG HM641JI (640.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) : 596GB (C:) (D:) (E:)
Seagate ST3500418AS (500.1GB, USB2/SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (G:)
hp DVD A DS8A5LH (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:)
Logical Storage Devices
SYSTEM : 199MB (NTFS)
FreeAgent Drive (G:) : 466GB (NTFS) @ Seagate ST3500418AS (500.1GB, USB2/SATA300, 3.5", 7200rpm, 16MB Cache)
Hard Disk (C:) : 577GB (NTFS) @ SAMSUNG HM641JI (640.1GB, SATA300, 2.5", 5400rpm, 8MB Cache)
Recovery (D:) : 15GB (NTFS) @ SAMSUNG HM641JI (640.1GB, SATA300, 2.5", 5400rpm, 8MB Cache)
HP_TOOLS (E:) : 4GB (FAT32) @ SAMSUNG HM641JI (640.1GB, SATA300, 2.5", 5400rpm, 8MB Cache)
Optical Drive (F:) : N/A @ hp DVD A DS8A5LH (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : HP HM65 LPC Controller
Audio Device : HP Cougar Point High Definition Audio Controller
Audio Codec : Integrated Device Tech 7605h
Serial Port(s) : 4
Disk Controller : HP Cougar Point Mobile 6 port SATA AHCI Controller
USB Controller 1 : HP Cougar Point USB Enhanced Host Controller #2
USB Controller 2 : HP Cougar Point USB Enhanced Host Controller #1
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Send To Microsoft OneNote 2010 Driver (1200x1200, Colour)
Printer : PrimoPDF (4000x4000, Colour)
Printer : Nitro PDF Reader Driver 2 (600x600, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : HP LaserJet P1505 (600x600, USB)
Network Services
Network Adapter : Realtek PCIe FE Family Controller (Ethernet, 100Mbps)
Mobile Broadband Adapter : QUALCOMM INCORPORATED 42 (GSM, 3GPP2)
Wireless Adapter : Atheros AR9285 802.11b/g/n WiFi Adapter
Power Management
Battery No 1 : Hewlett-Packard Primary 46.66Wh/3.76Ah
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 4.7
Old 02-17-2012, 01:25 PM
Turn wifi OFF when running Pro Tools. You might consider a better interface. I also own a Fast Track Pro and I have to say, the results with it are not good(worked fine with PT8, but stinks with PT9). I think M-Audio needs to deliver a new and improved driver. Mine will glitch or distort at any time(and I am running the latest driver). The new Mboxes(3rd gen) seem to be a better choice. I use my Fast Track/laptop for 3 things. 1-SMAART for PA tuning(works fine), 2-stereo recording in Wavelab(works fine) and 3-as an effects box when the sound system is lacking decent reverb and delay in the rack(M-powered 8 worked fine, PT9 is useless).
[IMG] code is Off
PT8 half speed playback, what the?! therecordinghouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-20-2008 03:38 PM
half speed playback help crushed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-29-2007 01:18 PM
Garbled itunes playback emelare 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-03-2004 10:29 PM
Mbox playback garbled... digital noise Gunnar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-22-2003 10:36 AM
No half-speed playback Sonny Pro Tools TDM Systems (Mac) 0 02-25-2000 11:01 PM
