Old 10-25-2010, 12:28 AM
RiF RiF is offline
Default Alternatives to Behringer ADA8000 for 8xADAT-Lineout conversion (auto-mute problem)?
I purchased a Behringer ADA8000 to get a total of 16 analog outs from my Digi 002R to go into my analog mixing console. But unfortunately, my unit has been built after 09/2009 and has this documented frakking auto-mute "feature" that renders it completely useless for me.
- Does anybody has a fix for that (other than putting Waves plugins with Analog-Button on on each track to keep the ADA8000's converters from going into sleep-mode)?
- Does anybody know of alternatives to that unit, which do not cost me 4x more?
Thanx!
Old 10-25-2010, 05:35 AM
barstool719 barstool719 is offline
Default Re: Alternatives to Behringer ADA8000 for 8xADAT-Lineout conversion (auto-mute proble
The Presonus Digi D8 is an 8 channel lightpipe preamp that costs about $400. http://www.sweetwater.com/store/detail/DigiMaxD8/ So it's only like twice as much as the ADA8000.
It has a nice sound and no real quirks that I am aware of.
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64
Focusrite Saffire Pro 40 / Pro Tools 9.0.3
Mics, Guitars, Amps, Basses, Drums, Keys
http://overtheeffect.bandcamp.com
Old 10-25-2010, 05:40 AM
cwsand's Avatar
cwsand cwsand is offline
But he needs a unit with 8 outs.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 10-25-2010, 05:47 AM
8 channels of audio
The DigiMAX D8 features 8 Class A XMAX mic preamplifiers, 8 direct analog outputs, and ADAT optical light pipe connectivity, making it the perfect solution to add 8 professional microphone preamps to any digital recording system or digital mixer with ADAT input.
Expand your system
If your audio interface is equipped with lightpipe, the DigiMAX D8 is the perfect way to expand your I/O. And with eight Class A XMAX preamps, the DigiMAX D8 has some of the best preamps available in this price range.
PreSonus DigiMAX D8 Features:
8 XMAX class A microphone preamps w/trim control
24-bit resolution ADAT digital output
44.1 and 48K sampling rates
External sync via BNC word clock input
Direct outputs on every channel
LED input metering
20dB Pad on every channel
which this has.
Old 10-25-2010, 07:53 AM
RiF RiF is offline
which this has.
Thanx for the info, but it hasn't. I am searching for ADAT->Analog outs, these direct outs are just the inputs routed back out.
Old 10-25-2010, 09:00 AM
FordVan FordVan is offline
RiF, using proper terminology will help people understand your need here.
You need Digital to Audio converters with ADAT inputs. Or, you could say: ADAT D/A converters. Most will understand that to be a converter that has ADAT input and analog output.
Old 10-25-2010, 10:03 AM
Sorry, but the D8 will NOT work here. The 8 direct outs are derived from the 8 analog inputs only. You need a unit with an ADAT INPUT as well as output. The Presonus Firestudio will do this. It comes with a software "mixer" that takes a bit of fudging to get all the routings correct(its NOT intuitive), but it WILL do 8 channels in both directions. A warning though, some units(the Firestudio in particular) will not be sample accurate. Not sure how much that means within the framework of your routing and mixing, but you need to be aware of it. The problem is due to converter latency. The Digi converters have a certain latency value(couldn't tell you what it is), so its pot luck whether your added converters(for the extra 8 channels) will exhibit the identical latency, or slightly more or less. Its never going to be so much that it throws off the timing of your music, but it can cause phasing if you pass the same signal thru both paths. As long as you route your tracks and stems correctly, it should not be an issue.
Where it was an issue for me, was with headphone mixes. I was sending the main stereo mix to the master inputs of a headphone amp, and then using extra lightpipe outputs for "more me" feeds to the headphone amp. When signals were turned up via "more me", they would cause phasing with the same signal that was present in the main mix.
Old 10-25-2010, 11:11 AM
pezguy pezguy is offline
The Alesis AI-3 will do the job nicely. Unfortunately it has been out of production for awhile. They do pop up on ebay quite often and can be had for around $200-300. Never had any phasing or latency issues either using the AI-3 with my 002 rack
Old 10-25-2010, 01:08 PM
cwsand's Avatar
which this has.
Yeah, sorry I didn't have time to elaborate, but Albee has explained it well.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 10-25-2010, 02:35 PM
I see. From his first post I thought he just needed something with the ins and outs.
edit: This guy will do what you need, and it's about $350 or so.
ADAT Input, 8 channel analog out on Dsub
Problem with my Behringer ADA8000 bombastiq 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-02-2008 08:32 AM
Behringer ADA8000 stevesound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 05-31-2004 01:40 PM
Behringer ada8000 hotstuff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-21-2003 07:01 PM
Connecting Behringer ADA8000 to 002 Rack problem coryadam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-21-2003 06:09 PM
Behringer ADA8000 Punx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 10-17-2003 04:00 AM
