Old 08-31-2009, 07:39 AM
tmoc-rocks tmoc-rocks is offline
Default M-Audio 1010 Signal Stutter record and playback issue
Hello-
Yesterday I was helping a friend get his M-Audio Pro Tools set up and running. Everything was going well until we recorded a test track. The track started to make quick stutters. It sounded like cosmic radio static stutter whenever a signal was coming in. It also happened on playback of said track. I raised the buffer size and that seemed to make a slower stuttering. My theory is that he doesn't have enough processor muscle to run the 1010 with the PCI card. We did a test importing a stereo Audio track from a CD and the same thing happened on playback.
He's using a 2.8 gig single processor, M-Audio 1010 with PCI card
Any tips or insight would be greatly appreciated.
Old 09-01-2009, 03:14 PM
jojo99 jojo99 is offline
Default Re: M-Audio 1010 Signal Stutter record and playback issue
an old 2.8?..probably not wise for lots of tracks/plugs of course.. but it should be able to handle a few as is. Depends how the sys is and setup though.
I personally would avoid the latest maudio delta 1010 driver btw.
Make sure it's setup correctly (mpanel)
Make sure other progs/resident apps are closed too.
* can you list the HDD/Raid controller name on your motherboard?
There is a known incompat with certain maudio cards and SIl ctrlrs.
No Signal - Possible audio Loop Issue Joshuajay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-30-2006 08:12 AM
Record-Enabled Audio signal silent during playback trevlino Digidesign Hardware & Software 3 04-06-2006 02:52 PM
How to record audio signal through SampleTank? Digitalkidd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-10-2004 06:58 PM
i want to monitor the input signal w/plugs during playback, but not record it... Joseph Grimm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-05-2003 04:20 PM
Weird Playback record issue Caution767 Pro Tools TDM Systems (Mac) 2 01-12-2003 01:38 PM
