PT7 *midi time piece not showing up in midi setup
hey all-
before you tear me a new a-hole for asking. I did a search but could not find. I thought I had seen a thread on this. So if someone would be kind enough to direct me there or give some wisdom on this topic, please do. I installed PT7 on a seperate start up drive, everything seems ok so far except for when going to the midi set up- my Motu midi time piece is not listed. just the network and the IAC driver. I tried draging over the old set up from PT6.9 but still no luck. Do i need to trash some prefs or some other mojo? I am hesitant about doing the upgrade over the older version 6.9 on my main drive because I have older sessions that are still being worked on.. but when I do go for the actuall upgrade will PT7 carry over all my PT6.9 , plug-in setting, midi set up and so on or will I get caught in upgrade hell? Thank you, pigmeat G5 dual 2GHZ, OSX.4.2 - PT6.9 HD 3, 192 I/O, control 24 |
Re: PT7 *midi time piece not showing up in midi se
needed updated driver for my midi timepiece to run with Tiger
downloaded at motu.com thanks pigmeat |
MIDI Time Piece obsolete? | RKrizman | Pro Tools TDM Systems (Mac) | 6 | 12-15-2003 03:06 PM |
Need help from synchronization experts. 001 and Motu Midi Time Piece AV | dkrausz | Pro Tools TDM Systems (Mac) | 8 | 01-25-2002 12:06 AM |
Need help from synchronization experts. 001 and Motu Midi Time Piece AV | dkrausz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-21-2002 10:36 PM |
MIDI Time Piece advice.... | Vik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-05-2001 12:35 AM |
MIDI TIME PIECE AV & 5.0 | BCM | Pro Tools TDM Systems (Mac) | 1 | 12-07-1999 03:01 AM |
