Old 10-23-2012, 06:53 AM
RenoLevi RenoLevi is offline
Default Pro tool + Elevenrack - no sound when starting session
Hi
I just bought eleven rack and im pretty noob with how to set it up
when i load pro tool i and click cancel on the start session windows its all good
i get the elevenrack window and i can control it
but if i start a session its all muted
what should i do? id there some setting i need to set up?
i just wanna be able to rec something along with the backing track
Old 10-23-2012, 08:26 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Pro tool + Elevenrack - no sound when starting session
Did you create a track?
You have to create a track in order to have something to record to.
If you did create a track, what kind of track?
If you want to record, then you need to create an AUDIO track, stereo or mono. Set the input to ELEVEN RIG L/R
Then you have to ARM the track, click the little red button on the track. then you should be set.
If not, then you need to default the IO.
http://www.youtube.com/watch?v=-Rjk5qVFEE8
Its definitely worth the time to read the manual, it will make your experience less bemusing and more fun.
good luck.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 10-23-2012, 08:59 AM
thanx dude
i did what u said but i just hear signal now
like no effects, just like bypass
how do i play with my eleven rack effect?
Old 10-23-2012, 09:10 AM
how do i set the imput to elevenrack?
Old 10-23-2012, 09:44 AM
Benoni's Avatar
you probably have the input set to guitar, you want to set the track input to Eleven RIG L/R. Look at the Track, above the fader you will see the words "I/O" just below that is a drop down, click it and choose Eleven Rig L/R.
Arm the track and play.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 10-23-2012, 12:06 PM
Peter Kroner Peter Kroner is offline
you better should open a "Guitar Tracking + Re-Amping" Session fom Start Menue ... at the first time ...
... after that you have to choose "Input Monitoring" in the Track-menue
(Spur auf deutsch)
if you choose "Direct Input " track you´ll have the input signal from guitar input
if you choose "E.-Guitar" you´ll have the output signal fromm 11rack
I bought the 11rack and PT10 one week ago ...,.
I think that it must work now ...
Old 10-25-2012, 06:20 AM
awesome! it works
can u guys help me with more stuff?
like how do i save a quick mixdown as mp3?
also i get random error MF: error something and it all crashes, happens alot
only way to fix it is restart the pc (using windows 7)
is there a fix for it?
Pro Tools session mixed in the box. Recorded with Elevenrack protoolsitb Eleven Rack 0 09-19-2012 12:54 PM
Session no starting at bar 1 Oroz macOS 8 08-03-2012 04:22 PM
Authorize problem when starting Pro Tool. Piano - 2008 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 04-24-2008 12:52 PM
starting a session? vickim Digidesign Hardware & Software 3 01-28-2003 12:49 AM
pro tool free = no sound, how to make it see my sound card? spencedavey Digidesign Hardware & Software 1 01-03-2001 02:15 AM
