Old 10-27-2010, 12:03 AM
uptowners2010 uptowners2010 is offline
Unhappy Studio Monitor volume setting
im just wondering what kind of volume setting people on here set their monitors . im having a hard time finding the right setting. i don't want to turn them up full blast but i also don't want to set them low because im trying to get the most out of my monitors. Right now they are set a lil bit past half-way any suggestions ? !
Old 10-27-2010, 02:45 AM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: Studio Monitor volume setting
decent calibrated monitors don't have to be anywhere near full blast.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 10-27-2010, 04:37 PM
The Weed's Avatar
The Weed The Weed is offline
Get an SPL meter.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 10-27-2010, 05:19 PM
FordVan FordVan is offline
Wow. Some great responses!
While both offer a slice of help.......sort of flippant.
Anyway, purchase or borrow a SPL Meter. Without going into too much fuss about it all, make a marking on your monitors volume control that signifies a roughly 80dB (A weighted Slow) reading for both mastered and unmastered material.
You need volume settings for both because, obviously, mastered material is going to be hotter than unmastered material. You will most likely be using mastered material to compare your unmastered material to, and might need to adjust your monitors volume to compensate.
It would be better if you could compensate in a more convienent way, but the above would suffice.
I would make all "final and crucial" decisions about your mix at a monitoring level of roughly 80dB A Weighted Slow. You can, for a majority of your time work at a little lower volume, but you really need to make your crucial decisions at around that volume.
If you want to get ultra technical, there are monitoring level tutorials. Bob Katz I believe has possibly the most authoritive writings on this subject. At the end of the day, you will be making your decisions at around 80db A Weighted Slow though...
Good luck.
Old 10-27-2010, 06:11 PM
Stig Eliassen's Avatar
From what I've heard and read A-weighting is mostly for measuring low-level noise in equipment. It rolls off a lot of the lows and low-mids, and emphasize the upper mids, so I don't see how this can be of any use in a studio?
Please explain. Thanks.
Old 10-27-2010, 06:28 PM
Noiselab Noiselab is offline
I use a calibrated SPL meter held in the imaging sweet spot and aim for somewhere between 70 and 80dB while aimed directly at either monitor. In a pinch I've even used the dB meter on my iPhone for setting levels. It's close enough for my purposes.
I used to mix at much lower levels until I learned that my mix "issues" were due largely to the Fletcher & Munson curve effect. I now track at the lower levels and spend very short periods of time performing mixing tasks at the higher SPL levels.
NL
Old 10-27-2010, 06:42 PM
Craig F Craig F is offline
Film cal in a nut shel is 85 dB band-limited pink noise (pink noise filtered to 500 to 2k, this helps over look room mode problems)
there is some room size variables (smaller rooms are lower)
it's a good staring point for music
Thank you,
Craig
Old 10-28-2010, 12:31 AM
High mids are where you hearing is most sensitive. You can hit 80 C Weighted and possibly not even be above your computers fan! LOL
Old 10-28-2010, 12:56 AM
I have tried both A and C-weighted, and C came out a bit softer, true. Well above the fan noise though. A gave me some crazy readings on the Phonic SPL meter I tried, but I did use full-range pink noise. Pilot error I guess.
Old 10-28-2010, 02:31 AM
I was trying to make a little joke about how quiet 80db C Weighted is.
Can Studio Monitor Express & Transport act as digital monitor controller? briancares Artist Series 1 02-04-2014 05:23 AM
Control windows volume with Studio Monitor Express? djmichaelwenz Artist Series 2 02-28-2013 01:03 PM
Monitor out togheter with monitor volume knob kennylovrin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-22-2006 08:19 AM
Setting up a second monitor? jwd65 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-07-2005 04:51 PM
just setting up my studio..help! brentm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-13-2003 11:27 PM
