Can you comp midi?
Can you comp midi like you would audio?
Intel 6 Core i7-4930K CPU @ 3.40GHz 32GB DIMM DDR3 G.Skill Samsung SSD 840 EVO WD Black SATA 7200 ASUS SABERTOOTH X79 Windows 7 Ultimate 64 Mbox3 Pro Firewire 400 ProTools 10.3.8 ProTools 11.3.1 https://soundcloud.com/matthewcrowe |
Re: Can you comp midi?
Do you mean Compress? Like audio compression?
Sort of... You can edit the velocity of your performance and limit its range. For example, if you performed a piano part and the dynamic range (in MIDI terms) went from 20 to 127, you could "squash" this to be from 60 to 120. In a way, like compressing the upper range, and expanding the lower range. I hope that helps |
No, comp as in track comping/loop record.
Unfortunately, no. Hopefully we'll see this soon in a future release.
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
+1000
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
+1 |
Oh yes, I also can't wait for PT to playlist midi like it does with audio Meanwhile, you CAN do it...sort of, depending on what you are doing with the midi. Say for instance, you are using a VI plugin(let's use MiniGrand for an example). Put up an instrument track with the plugin, and a few midi tracks, select to show CLIPS and record a pass(on the instrument track). Once its reached the end, drag that midi to one of the midi tracks. Now do another pass on the instrument track. Each time you finish a pass(with stuff worth saving) just drag the midi OFF the instrument track and ONTO one of the midi tracks. Once you finish recording(and ALL the midi info has been moved to midi tracks), switch to notes view, and assign all the midi tracks to the MiniGrand plugin and unmute midi tracks(one at a time) to hear how they sound. When you find parts that are "keepers", copy them back to the instrument track(highlight the midi on the midi track>copy>use the P & ; keys to move to the instrument track>paste. When you finish "comping", kill all the midi tracks and the instrument track should play with all your desired parts. Get creative with HOW you work, you you may find it easier to be musically "creative" within the boundaries of PT
Playlists work the same way on instrument tracks as they do on audio. Just make a new playlist for each take.
The only difference is you can't switch the view to 'playlists'. So you just duplicate the track say 5 times (for 5 takes) and empty out the original track to become the comp track and set the playlist of the 5 take tracks accordingly. Takes just a second. Then you can use the solo button on each take track and pick out the pieces you want and slide them up to the comp track. That's what I do anyway.
DC-Choppah's Project Studio: ASUS PRIME Z390-A / Intel i7 rackmount PC Windows 10 home 64 bit Pro-Tools 11.3.1 AIR Instrument Expansion Pack v2 WAVES Platinum plugin bundle Tascam US-16x08 Interface 100% Analog real time monitoring 16x4 Yamaha 16 channel MG16XU Analog Monitor Mixer Yamaha MX-88 / Novation XiO keyboards Mackie 4-channel headphone amp Adam A8X monitors Blue / Shure, etc. microphones Estonia 6' 8" Parlor Grand Piano Yamaha Studio Drum kit https://www.dc-choppah.com/ |
midi track record turns off all other midi/instrument tracks delay comp | holyspicoli | Virtual Instruments | 4 | 07-18-2013 06:14 AM |
Please help confirm a midi/delay comp bug | Kristo Kotkas | Pro Tools 10 | 6 | 06-25-2013 04:00 AM |
Can I do Multiple Midi takes then comp? | TheBaron | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-10-2010 02:46 PM |
Midi learn in PT 8 and bus delay comp | peter99 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-18-2009 12:43 AM |
PSP Master comp, nearest plugin comp to Manley Vari MU? | crizdee | Pro Tools TDM Systems (Mac) | 1 | 05-22-2007 05:21 PM |
