  #31
Old 05-04-2014, 08:53 AM
Default Re: Track Presets in Pro Tools 10
Originally Posted by frederic Bacquet View Post
Hey again,
As I told befor, I knew your "links".
So... do you think I tryed it before to post on that forum???
For your information, it doesn't work with protools 11 on pc. If you look at that video you will see that the subfolder is created in C/ x86 folders (32 bits) : PT11 is in programmes folder (64bits). That's why !!!!
So, if someone knows how to make it works for PT 11 in windows 7, it will be really helpful.
One other solution should be that for any reason, it doesn't work for MY computer.
Like I said - you have to know the folder structure for where to put them presets and that is covered in the thread I linked to. It worked for other people so unless you have something totally weird going on on your computer it will work for you. You just have to lose the attitude, that's all. And the track presets folder doesn't go in the program folder.
Forget the video and look at the thread I linked to - your answers ARE there. You'll find it goes in a folder tree off the My Documents folder just like Oliver M says it does.
I'm trying hard to to go off on your snark but it's getting difficult but don't worry because I don't play those kinds of games. I'm trying to help and if you can't see that then that's not my problem. I've seen your replies in another thread here where you went off on someone who didn't need it - that kind of 'tude will get you nowheres.
Jack
QAPLA!
  #32
Old 05-06-2014, 07:44 AM
frederic Bacquet frederic Bacquet is offline
This just doesn't work...
Could you admit that???
  #33
Old 05-06-2014, 08:06 AM
So for those how wants the information :
Presets (folders and subfolders) won't appear before you create a first preset.
So Document / protools / Track Presets / subfolder (routing master for example) / Subsubfolder (2 aux + master for example) / file you save as template (anything will appear before you create that first template.
If it can help someone. (better than just giving a link).
  #34
Old 05-06-2014, 11:42 AM
Your description of the workflow is just plain wrong. Creating presets does not automatically create the folder it resides in although you can work that way. The folders can be created BEFORE you create track presets.
It does work for many people - can't you just admit that? Just because you can't make it work is your issue. I tried to help and gave you links to places where it's talked about that it does work but if you don't want to follow that then I can do no more here and have wasted my time trying to help someone in good faith.
Jack
QAPLA!
Track Presets Kenny Gioia Tips & Tricks 30 01-31-2014 04:33 PM
Track presets in 11? albee1952 Pro Tools 11 2 06-24-2013 04:37 PM
Track Presets!!! albee1952 Pro Tools 10 8 12-29-2012 08:13 PM
Track/"Channel Strip" Presets DO exist in Pro Tools, apparently... PTPhillip Pro Tools 10 97 10-20-2012 01:03 AM
Track presets in PT??? dgkenney Pro Tools TDM Systems (Win) 3 12-22-2009 10:03 AM
