Old 11-11-2009, 09:14 AM
tobbenos tobbenos is offline
Default Moving MIDI notes and control data (sustain) simultaneously?
Hi!
At the time, I'm editing a MIDI track (fed into Mini Grand) to fit a vocal track. That means moving the notes quite a bit. The MIDI was recorded using my MIDI keyboard, and is very dependant on the use of the sustain pedal. The problem is the following:
Let's say I've marked the whole track from a certain point and to the end, and I want to drag the notes a couple of seconds backwards. The sustain data stays in the exact same position, and I cannot find a way to move it. This leaves me having to manually edit every single one of the sustain on/off-points.
Old 11-11-2009, 07:35 PM
Default Re: Moving MIDI notes and control data (sustain) simultaneously?
Is 'Automation Follows Edit' enabled?
filosofem
Old 11-12-2009, 08:09 AM
QPro5-AM QPro5-AM is offline
filosofem
I bet'cha now it is
Tought me something new tho! Thanks for the heads up
Thank You,
Shawn
QPro Entertainment
Old 11-12-2009, 11:11 AM
Yes, it is.
Old 11-15-2009, 05:29 AM
So – noone knows? Am I left having to move the sustain data manually?
Old 11-15-2009, 05:23 PM
tobbenos can you post your system specs including exact OS and Pro Tools version and troubleshooting tips you have tried?
filosofem
Old 11-17-2009, 01:59 AM
MacBook Pro 2.2 GHz, 2 GB RAM (MBP ver. 3,1)
OS X 10.5.8
Pro Tools LE 8.0.1
Mbox 2 and Mbox 2 Micro
With regards to troubleshooting: I do not know if this is and error or if it's only me not knowing a certain technique. Therefore, I cannot say I have done specific troubleshooting. However, I've tried enabling and disabling "Automation follows edit", using different marking (dragging the marker tool over both the midi track and the sustain data subtrack), using different tools and edit modes.
Is there at least a possibility to drag segments of the sustain data, and not just the individual control points? E.g. marking a segment of the sustain data subtrack, and use the grab tool to move it.
Old 11-17-2009, 06:31 PM
If you copy and paste the region to an Instrument can you select the region and drag it down the line and does the Sustain breakpoints follow with the VCA Lane open? What about they Automation? Have you also tried a sustain pass with a new session?
filosofem
Old 11-18-2009, 07:30 AM
daeron80 daeron80 is offline
I'd guess that you're selecting and moving the notes in Notes view. You need top be in Region view, split the region at the point where you want to move it, and drag or nudge the whole region(s).
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 11-18-2009, 08:15 AM
Yeah, I've thought about that, and that works. What I wanted to do, was to move a segment of notes and move it, though that seemingly is impossible.
Dropped notes, sustain problems, random notes Gamling MIDI 4 02-10-2014 07:09 PM
More effective editing of Notes and Sustain on a Piano (MIDI) track Stig Eliassen Tips & Tricks 4 08-05-2013 07:35 AM
Moving Controller Data with Midi notes Swar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-29-2009 09:38 PM
MIDI notes don't sustain after being pasted jimthepisces MIDI 1 01-08-2008 06:28 PM
Moving MIDI Notes Dog BBQ Pro Tools TDM Systems (Mac) 3 10-12-2000 06:02 AM
