Re: 44, 48, 96, 192 Kz sample rates...
What might be a good happy medium is to track simple stuff with only a few tracks (like singer-songwriters, basic acoustics stuff, etc.) at the higher rates, and at 44k for stuff with lots of tracks.
Is it possible to record everything at a lower sample rate, like 44 or so, and then record the vocals at 96 (because they are the most noticeable and usually are tuned) ? It doesn't seem like it should work, but if it did that would be amazing.
I'm not sure that would be the best idea, but one way to track at lower sample rates for instruments than higher for vocals would be to save your session at 44.1, then start a new session, at 48, 96 or what ever and then use session import to upconvert the audio from the other tracks into a new session. But of course then you would have a high sample rate tracks and the originals taking up space. Just a thought
Or you could record the instrumentation at 44k, than import them into a 96k session, record the vocals in that session at 96k. Then put the vocals through melodyne, and after they're tuned import them into the first (44k) session. A little bit more work.
Thanks folks for your inputs. Very interesting to read!
MacBook Pro - OS X 10.6 - Pro Tools LE 8 - Mbox 2 Drone / Ambient / Experimental |
#16
Derek Jones Sound Engineer / Producer / Composer Derek Jones Linkedin Megatrax Recording Studios Megatrax Studios Yelp Page A-list Music Artist Page |
#17
Why bother? Just record at 96KHz if you feel you need to. It's not going to "hurt" the other tracks. And the tracks aren't going to "sound" better at 44.1KHz anyway... so there is no benefit to jumping back and forth. You are better off just recording at 96KHz to begin with.
#18
Ya your right. But I've read articles pertaining to using 96KHz to gain ?? something. But now I can't find the article. Something along the lines that 96KHz giving more room for effects etc before clipping. Don't quote me on that I'll have to find the article. I believe it was in Sound on Sound, but I'm unsure. Now I have to find it, It was very informative.
#19
This was interesting I thought,
#20
one problem I have with that post is it is assuming that quantization noise only happens at the nyquist frequency. but it doesn't. It is broadband as far as I know. If it were only at nyquist, a simple filter would be enough to stop quantization noise. But that is not the case. Dither is needed to stop quantization noise.
Focusrite Saffire 56 Sample Rate Problems - Sample rates changing during start up | finalcut | Windows | 12 | 02-20-2012 04:00 AM |
6.4 LE Sample Rates | whayne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-13-2004 09:39 AM |
Sample Rates? | rtm | Tips & Tricks | 3 | 05-02-2004 07:49 PM |
Session sample rates & Soft Sample Cell | soundboy35 | Pro Tools TDM Systems (Mac) | 4 | 10-26-2003 06:11 PM |
Comparing Bit-rates, Sample-rates, and convertors - Telling the difference? | stoogee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-05-2003 08:36 AM |
