Getting bass to standout
Working on my bands album, and I'm having a problem with the bass guitar. It seems to be very boomy at some parts, other parts it's very thin and gets lost in the mix (and the bass player isn't playing high notes when it gets lost). I understand that compression is supposed to level things out, but it's not helping much (just seems like it makes it louder, but the level is still all over the place). Any tips on solving this? I have compression set on the "Bass Guitar" preset, and I'm not really sure where to go from there.
Here's my specs in case you need them: Gateway X2800, Quad Core CPU, 2.5. Windows XP Pro Digidesign 003 Rack Pro Tools 8 4 Gigs of Ram External firewire drive 160 GB. |
Re: Getting bass to standout
Hi I have the same thing happen with bass alot.
First if your getting the "Brown NOte" or several that seem to shake or resonate everywere, then use your eq and isoloate that note. Do it note by note if you have to and youll find the freq thats doing it. Then notch filter it with the EQ. Once you get that under control then boost the low volume notes the same way. Just sort of ball park it with eq then compress. If its still doing it then put a limiter behind it. If its a recorded amp then you might be getting some comb filtering happening in the room you in. If its DI to track then try compressing some going in the box. |
When using compression the signal should get quieter, as you are actually reducing the dynamics. Use the add gain to bring the level up a little (sounds like your add gain is cranked quite high at the mo). Also if it still 'all over the place', the compressor may be 'pumping'. Try to lower the threshold a little and slow down the attack and release.
I also find that giving a little high frequency EQ can pull the sound of a bass guitar out very well (this is even more true when mixing double basses, in particular for live sound). It seems a common myth that the low frequencies must be boosted to hear the bass. cdavis has also put forward some good sugestions. What else do you have going on the mix that you believe is muddying the bass? A:)
I Love Audio!!! |
Thanks for the replies guys, I'll see what I can do using your tips.
To answer your question, 1ace1, I have some distorted guitar tracks going. I haven't even thought about the bass level on them. I EQ them, but just raise the mids/highs a little. Maybe I can take down the lows on them some and see what happens. Thanks again! |
Good plan. Try a HPF (bass roll off) on the distorted guitars, this may give more space for the bass to breathe.
Happy mixing A:)
I Love Audio!!! |
With Bass guitar... it's all "In the source" - once it's printed that way, it can be the devil in a mix, and it's not as responsive to multi-band compression as Higher frequency stuff, like vocals, and guitars. You say, "Working on My Band's Album" - if this is your Bass Player, I'd really have him "Work on his sound" when doing further recording. Try different Basses, Pickups, Rig's (Amps / Compressors etc...) - and compress, using a Hardware compressor, on the way In (Easy does it) When it's "Right" from the source, bass is usually the least problematic track in a Mix. I've handed many records in, where the Bass was literally "Faders Up" on the record - with a little HPF. I'm lucky to mix quite a few records, that a few of the same Bass Players are on the sessions, that have incredible Basses, Gear, and Hands - and it makes a HUGE difference, from some of the problematic sessions I am Handed to mix. The same philosophy goes for ALL playing, and tones - But Bass is the foundation that your whole mix stands on - if it's boomy, taking off, or you bury it... it's a bad mix.
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
Is the bass track done with a DI or a mic? If its a DI track, use an AUX send to a mono AUX track and insert and amp simulator plugin(I like the IK Amplitube tube preamp/50 watt tube power amp) to add some grit and girth. You could also try duplicating the track and use HEAVY compression on the duplicate(like BF76 with all buttons pushed in) and mix that track underneath the original. Plenty of good ideas in this thread so here's hoping some(or some combination) will help.
If you have the tracks spare I would always mic and DI a bass for maximum flexibility when mixing.
A:)
I Love Audio!!! |
Yeah, the bass player will have to do her parts over again, but it'll be worth it. |
Record bass w/ Ampeg SVX - just plug bass into MboxPro or go in w/ DI like SansAmp? | Squid Vicious | Eleven Rack | 10 | 12-31-2012 01:46 PM |
Best bass loops for vintage bass? | el biciclista | Pro Tools TDM Systems (Mac) | 3 | 04-06-2008 04:17 PM |
Bomb Factory/Bass Pod for Bass Tones? | accameron | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-14-2002 05:21 PM |
bass / kick and bass management | AdamFrick | Post - Surround - Video | 7 | 12-26-2001 07:52 AM |
BASS BASS BASS BASS PROBLEMS | sugarfuzz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 28 | 10-13-2001 04:49 PM |
