Old 06-15-2014, 04:49 PM
Ghost219 Ghost219 is offline
Default Hello 11R. Goodbye HD500. (on Thursday)
Let me preface this post by stating that for YEARS, I wanted an Eleven Rack. Monetarily, it wasn't feasible as it was only available bundled for a LOT more than I had to spend. This is why I went with the HD500. So I learned my way around it and adapted to it's "sound". I started going direct with it one side going to a powered wedge and the other to the PA. It seemed to sound fine that way for a while but then I started running it as a head into a Line 6 Spider Valve 2x12 and found it didn't sound all that great without using my Aphex Aural Xciter. I'm not a noob. I made sure to set it for use w/ a combo amp and turned off cab emulations. When I ran it direct, I used a 2x12 cab model.
Will I need to continue using the Xciter for added body and girth or is everything onboard sufficient?
I know it's late to ask now that it's on the way. I saw it for a really good deal online and jumped on it and the general consensus is that it's amazing.
Thanks, all.
Old 06-15-2014, 05:56 PM
CME CME is offline
I run mine straight to the board with out any extra processing. We use IEM's so I don't know about using a combo amp with it. A nice powered speaker might be a better solution with the 11r. But just hypothesizing.
Oh and I do think you'll like it. It's the first modeler I've used that I haven't grown tired if after a few months. Heck I've basically got one patch that I've stuck with for a good while. It's an ac30 based rig with a white boost in front and some reverb, delay, and rotary speaker afterwards. Don't even use any EQ's with it. I can go from clean to plenty of gain for my style with it.
So if ever I get tired of it, I'll just start a new preset with a different amp. That ought to keep me happy for another couple years at least. I can repeat that cycle for a long time lol.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Old 06-15-2014, 06:28 PM
Default Re: Hello 11R. Goodbye HD500. (on Thursday)
Thanks for the reply. I'm wanting to use the amp for the tube power section. Plus, I have a feeling a lot of the clubs I'd be playing won't be properly set up for that type of set up. Also, I don't have IEM's or a powered speaker (anymore).
Old 06-16-2014, 12:00 PM
Barry Johns Barry Johns is offline
You are not alone. I tried very hard to get it to sound good on several Tube Amps (Marshall/Mesa Boogie), using the send return, front of the amp, and finally 11R-Marshall Tube Power Amp - (2) 2x12's. All sounded like crap!
11r straight to PT ++
11r straight to full range setup ++
Anything else ��
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 06-16-2014, 12:07 PM
Even the 11R sounded bad through an amp? I'd be running it through the loop as well.
Old 06-16-2014, 01:42 PM
CME CME is offline
IMO the issue with using any modeler with a tube amp, is that tube amps are tuned "systems". And the power amp may or may not compliment the 11r. Not saying it can't work, but something designed to be "neutral" will probably work better.
Old 06-16-2014, 01:44 PM
Pingafuego Pingafuego is offline
I ran mine through Hot Rod Deluxe effects loop and it sounded great. But with different settings than running through rokit studio monitors.
Old 06-16-2014, 05:39 PM
agreed. I probably wouldn't want to use an EL34 amp with any modeler as they impart more mids and honk IMO. My amp uses 6l6's but the signal path runs it through some 12ax7's. It sounds good in theory but it may lend to more break-up than wanted.
Old 06-16-2014, 05:40 PM
Interesting. What was different in your approaches for each?
Old 06-16-2014, 08:43 PM
zedhed's Avatar
zedhed zedhed is offline
Run the 'To Amp' output to your amp and XLR outs to PA and you have the best of both worlds. As long as 'To Amp' is positioned pre Amp/Cab sim, your sending a signal as if you were plugging straight into amp.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
11r + pod hd500 balance Eleven Rack 28 03-16-2018 08:57 PM
Free audio engineering seminar this thursday bristolstudios Pro Tools 10 0 06-12-2012 02:37 PM
Need ADR Room In Miami for this Thursday dr sound Post - Surround - Video 2 04-27-2010 12:19 PM
Just got my Icon on Thursday....... Jonathan Wales ICON & C|24 3 10-11-2005 05:00 PM
THIS Thursday's Press Conference meltedmediamusic Tips & Tricks 1 12-28-2001 11:34 AM
