Old 08-26-2005, 06:16 PM
proverb18 proverb18 is offline
Default Audio files dissappear when using header finder...
I posted a few days ago about my audio playing back faster after recording through the s/pdif from another board. i was told to use rails app "header finder" to fix the sync problem. When I do the files dissappear off my hard drive! Am I doing it wrong or is there another way to convert the files back to 44.1/16? i tried "save session copy in"...Would really like a solution since I deleted the original zip disks after recording to pro tools. luckily I didn't bounce in my best stuff! Rail?
Shawn
Old 08-26-2005, 06:54 PM
Default Re: Audio files dissappear when using header finder...
Shawn
I'm confused too... explain what you're doing exactly.. and when do the files 'dissapear'?
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 08-26-2005, 08:25 PM
hey rail...what happens is this: I run the app and change headers as I should I think? Do I change all 4 or just sample rate and bit? Anyways, after it is done I go in to my session to open the files and they are blank noise! even the back-up files are that way. ???
Old 08-26-2005, 08:32 PM
You shouldn't change the resolution.. just the sample rate.
So the files aren't disappearing... the format you've changed in the header doesn't match the audio data in the sound file.
Rail
Platinum Samples
Old 08-26-2005, 08:35 PM
Thanks, I'll try that and see....
Old 08-26-2005, 08:39 PM
I did that and it still says,"some of the files cannot be found, would you like to re-link?" I do that and 2 files came up but the vocal was gone...the files that came up were still too fast...???
Can't drag audio files from Workspace browser of finder. soundkurt Post - Surround - Video 4 02-18-2015 12:06 PM
Locking audio files in OSX finder saw Pro Tools TDM Systems (Mac) 2 06-20-2009 05:37 AM
Bounced files on desktop just dissappear mylar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-06-2006 02:54 AM
Bounced to disk files on desktop dissappear? mylar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-05-2006 11:19 AM
Exported WAV files - wrong header? in10shun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-01-2002 12:52 AM
