Old 12-15-1999, 04:47 PM
tld tld is offline
Default Power Tower Pro 225 / Newer Tech G3 Question
I have a Power Tower Pro 225 and a Newer Tech G3 300/200/1M upgrade to put in it. I have two questions about their install intructions for the PTP 225.
You have to press the mother board reset, and they say to check your owners manual for its location. If anyone can give me an idea of where that is, I have a used machine with no manual.
The instructions also talk about removing the side and top covers. The side comes off, but the rest of the chasis isn't going anywhere without doing stuff like removing the power supply. Is there any reason to remove more than the side panel? The only reason I could think of would be to brace the opposite side of the motherboard when pressing the card into place.
Thanks in advance for any advice.
Tom Dexter
http://www.digitalaudiorock.com
The Protools Plugin Preset Co-op
Old 12-16-1999, 03:51 PM
motive motive is offline
Default Re: Power Tower Pro 225 / Newer Tech G3 Question
The reset buttom is called the Cuda or cudos its a little red button on the main board..I own a PTP 225 and PCP 180 so I forget which location is which and dont wanna screw you up..but I can tell you..it looks like a mini button..the only thing in there that even could be pushed...And I think the board even has it labled as Cuda reset..so look for that..hope that helps
9600 Mac migrating mix plus to newer G4 tower bigtree Pro Tools TDM Systems (Mac) 7 12-14-2008 05:11 AM
G4 Tower fan noise - need a low tech solution. Raymond Hardy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-14-2003 12:32 AM
Newer tech ppeople Tal Pro Tools TDM Systems (Mac) 3 10-04-2001 12:48 AM
Newer Tech G4 450 bigtree Pro Tools TDM Systems (Mac) 1 07-15-2000 01:07 PM
Newer Tech G 3 or G 4 Kurtstudio Pro Tools TDM Systems (Mac) 4 04-19-2000 07:27 AM
