Old 02-14-2020, 02:57 AM
crizdee's Avatar
crizdee crizdee is offline
Default Xmon issue
My Xmon has been having some issues. it was doing the going into mute mode randomly and also the left channel out on the ALT outputs would drop in level and occasionally cut in and out.
I did what i always do and completely stripped the Xmon and cleaned every connection and cable and put it back together and it seemed to fix it for a month but the issue is back again.
I have 2 D command main units so swapped the monitor section over so i don't think its within the D Command. also changed the cable between Xmon and D Command.
Now today is seems to be dropping level on the left out on all the speaker outputs, Main, Alt and Large.
Toggle XMON on and off and it fixes it for a while.
Guess there's not much more i can do but buy another Xmon
Chris
Producer, Engineer,
www.ukmastering.com
Xmon zmagosmon Buy & Sell 0 04-03-2019 09:04 AM
XMON Issue RobSound ICON & C|24 1 06-21-2018 03:27 PM
XMON issue inf0l ICON & C|24 1 09-07-2016 07:18 AM
Old XMon on S6? paulo m Avid S4/S6 15 08-20-2014 03:22 AM
Xmon mod?? mtung ICON & C|24 0 10-01-2009 05:16 AM
