Old 09-29-2018, 02:00 AM
surreall surreall is offline
Default Bit rate
Hi, how I do to choice bit rate of project in PT first if possible, I searched but I didn't find anything, thanks for help...
Old 09-29-2018, 05:28 AM
amagras amagras is offline
Default Re: Bit rate
When you are creating the session you can change the bit rate. To change the bit rate of an old session you have to save a new copy (File>Save Copy In) but I'm not sure that is available in PTFirst
amagrasmusic.com
Old 09-29-2018, 09:20 AM
Thanks, but there is not options to choice or change bit rate when creating new session, and the default is 32bit
Old 09-29-2018, 10:57 AM
Must be a PTF thing, anyways you can't go wrong with 32bit.
amagrasmusic.com
Old 10-01-2018, 11:38 AM
junkgear's Avatar
junkgear junkgear is online now
Pro Tools First is 32 bit only. Higher versions of Pro Tools allow you to select different bit depths when creating projects.
Will
System Details
Old 10-01-2018, 12:47 PM
Ok thanks!
Old 12-21-2021, 05:29 AM
[email protected] info@andrewhubbard.com is offline
But there is no mp3 Bit Rate control in PT. ACX need Bit Rate (not bit depth) of 192kbps or higher. help :)
Bit Rate / Sample rate supersam83 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-25-2010 08:55 PM
auto matching pull factors + frame rate + timecode rate Dingo90 Post - Surround - Video 1 10-17-2009 04:16 AM
Bit Rate/Sample Rate problem? The chipmunks? bspro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-17-2008 05:40 PM
mp3 bit rate question 128 / 320 ? constant bit rate TREBLEBLEED 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-04-2008 02:07 AM
QT 23.98 video frame rate... timecode rate? dopplah Post - Surround - Video 10 07-03-2007 05:28 PM
