Old 08-23-2002, 02:00 PM
Captain_Pants Captain_Pants is offline
Default Re: Bugs on 5.3.1
Are you guys talking about a white shadow in the backround when dragging your transport? kinds like it is a big roller and painting everything white as you drag it? if so, that is something you can turn on and off in windows, and not related to protools.
If that is what you are talking about.
Ill suffer winter alone;
ten thousand miles from home...
Old 08-23-2002, 02:36 PM
Dreamware Dreamware is offline
Actually that screen redraw problem is related to protools and not windows. Digidesign has already stated that this a known bug.
Alex
www.dreamware.ca
Have something to brag about...Own a Dreamware Audio PC...
My Rig:
AMD Athlon XP 1700+
512MB PC2700C2 Corsair
MSI KT3ULTRA ARU
2x 80GB Seagate Barracuda 4 in RAID 0
GeForce 2 Ti 64MB
Lite-On 40x12x40 CD-RW
16x Pioneer DVD
Intel Pro/100 +
SB Audigy
Digi 001
Old 08-23-2002, 03:08 PM
keny keny is offline
There are two possible issues here.
1 the screen not redrawing itself while moving the transport can be changed in the control panel.
2 when you are moving a window while playing back, all the green audio meters freeze and that is the known bug.
I would recomend getting rid of any effects that your display control panel is using, including shadows and fade in's on the pull down menus.
The waves plugins take so long to show up in the plugin menu that any optimization there will be helpful.
As for the mouse issues I was using a Kensington "Expert Mouse" trackball but I was getting too many bugs with it so I was forced to go back to a plain ol' optical mouse. I do miss the trackball, and my pointer finger hurts from having to stretch over to that left mouse button. Hopefully they'll have better support for these types of peripherals at a later time. Maybe even going as far as adding a keyboard and mouse port on the 001.
just to toot my own horn, I am in the process of relocating to Los Angeles and lookign for a job, so if anybody knows someone who can help me get established as an audio engineer and producer, check out my creds at http://www.kenyruyter.com and call me 310-909-9115
myspace page
Old 08-23-2002, 04:30 PM
Vaphoron Vaphoron is offline
So...Can anyone confirm that they too are getting the bug of trying to copy a region while in shuffle mode by holding down the alt key and dragging? This one bugs me!!
Jason
- Jason
Old 08-24-2002, 12:40 AM
Default Bugs on 5.3.1
I am normally on a Mac but I finally got around to firing up my second workstation which is a PC with a Digi001 running 5.3.1 on Windows XP Pro. Anyway, I noticed two things while I was working. I don’t know if anyone else has experience them and unfortunately I don’t have the time to search the DUC to see if anyone has. The first occurred in the mix window. I was trying to select tracks and drag them into a new position and they didn’t really want to move. Its like the mouse just wouldn’t move and as soon as I released the mouse button everything was fine and I could move my mouse again. The second thing I saw was when trying to copy a region while in shuffle mode, I was not able to get it to work. If I switch back to slip I can copy just fine but as long as I was in shuffle it would not let me copy anything. Sorry if you all knew about this already.
Jason
- Jason
Old 08-24-2002, 12:44 AM
LEVON LEVON is offline
YES,i have the mouse being slow to the point it almost like freezing evrey now and then.another thing is happening in 5.3.1, when you drag the transport or any other thing you'll see a shadow in the background untill you release the dragging.does that happen with you?
Old 08-24-2002, 12:57 AM
Yes, as far as the screen redrawing when you move the transport bar or the counter window, I am getting that also. If I recall, this is something that happened in all the older versions as well. Have you tried the bug with holding the "alt" key to copy a region while in shuffle mode? For me, that is something that is a big pain cause I use that so much.
Jason
- Jason
Old 08-24-2002, 11:13 AM
So you have a track with an audio file and you want to copy it in shuffle mode. Where are you trying to copy it to?
the rules of shuffle mode is that the file to be copied has to fall back to the previous region. Try this: make a region about 10 seconds into a session, switch to shuffle and try to alt drag the region into a new track. Then try to do the same thing but drag it to the beginning of the new track. You should only see the "square" in places whee you can copy the region. I think this should outline the limitations shuffle mode a little more.
myspace page
11.1.2 on Mountain Lion bugs bugs bugs. command+f, elastic audio, discoloration farmfresh Pro Tools 11 21 05-01-2014 07:21 PM
PT8 bugs murergobben 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-24-2009 04:07 PM
Bugs in my box - no, REAL BUGS !!!!!!!!! Mixtrix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-25-2006 06:33 PM
Old, old bugs Pete Gates Tips & Tricks 2 02-14-2006 09:10 AM
bugs in 5.3.3??? Matt Zeiner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 28 01-03-2003 07:07 AM
