Old 12-17-2021, 07:29 AM
counterpnt counterpnt is offline
Default Re: MIDI controller active but no input
Originally Posted by Ben Jenssen View Post
Again I ask, what VI have you on the instrument track?
Sorry I missed this part of the question before.
The latest I tried was Vacuum. But also, I've tried this using MIDI tracks (obviously no VI there at all) with the same result.
Old 12-17-2021, 11:33 AM
Hi everyone,
Finding out that PT11 is not technically supported for Win10 prompted me to upgrade to the latest version of PT. I'm hoping that'll solve the problem. If not I'll repost in the more modern forum. Thanks!
Old 12-19-2021, 04:07 PM
albee1952 albee1952 is online now
Under Setup->Peripherals, all are set to "none".
Under Setup - > MIDI -> Input Devices, "Roland Digital Piano [Emulated]" appears and is checked
Under Setup -> Preferences - > MIDI tab, the Default Thru Instrument is set to "First selected MIDI track"
None of the above matters on a Windows machine. What DOES matter is the proper setup in the following menu(from within Pro Tools):
Setup>Midi>Midi Studio.
1-In this menu, create a new "instrument" and name it as you like.
2-Brand and model can remain blank(these settings don't affect function)
3-Input Path is the crucial setting and "Roland Digital Piano [Emulated]" is most likely correct.
4-Lastly, make sure(for now) that all 16 midi channels for INPUT are selected.
This tells Pro Tools were to "look for" incoming midi data. The output path and midi channels won't matter unless you need to send midi back to the keyboard to play its on-board sounds. For testing purposes, create a new stereo instrument track and insert MiniGrand in the top slot. Once the plugin loads, mouse-click a few keys on the plugin to verify the plugin is loaded and working. Put the track into record-ready and play your keyboard. If it makes sound, you're all set. If not, then we have more troubleshooting to do.
Virtual MIDI Controller other Midi input then ALL? Luigi2000 Pro Tools 0 11-15-2021 02:31 AM
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input yellow Eleven Rack 1 05-04-2012 03:33 PM
tap tempo input from midi controller? rpm1nj MIDI 1 09-20-2009 07:33 PM
tap tempo input from midi controller? rpm1nj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-19-2008 11:20 AM
OSX Midi Controller Not Seen on Input Average_Joe MIDI 16 12-10-2006 02:57 PM
