  #1261
Old 05-02-2019, 06:12 PM
jasonkalman jasonkalman is offline
Default Re: Pro Tools 2019 !
Originally Posted by LDS View Post
The point I was trying to get across is that is very much a system specific thing. There are so many different plugins, from so many different developers, that have released so many different revisions that run under so many different OS configurations and installations that a simple list would undermine the very complexity of the problem. The importance isn't the crap plugin... it's the fine tooth comb in the plight to for a stable system.
After going through all my plugins about 18 months ago, I found that Slate's stuff really added to CPU overload errors and weird CPU consumption, so I cancelled my subscription. DearVR Pro would randomly crash Pro Tools under certain automation and output configurations, which I flagged with PA and they have subsequently released a new version that fixes it. The facebook 360 stuff has caused me a whole lot of grief. But even after those big three, I went through and deleted all of the free or cheap plugins that just congregate in my plugin list but never get used. It probably reduced the plugins that I have installed on my system by about 40%.
Since then, I have probably had a dozen crashes in Pro Tools working across two systems. Most commonly, they occur when I close Pro Tools, and it crashes instead of quitting neatly. Yesterday I suddenly started having CPU overload errors in Pro Tools for the first time in a very long time despite the CPU meter being at 10%. It was the direct result of having installed and initiated Dehumanizer 2.
If you are having issues with stability, there really isn't any point in blaming Avid until you have actively pursued every other developer's piece of software that you are trying to use with Pro Tools as the potential cause. It was something that at least used to be taught right from the very beginning of using Pro Tools, along with trashing preferences, and setting up your I/O.
Great thanks for the info. I knew Plugins caused stability issues, I just didn't know the specific ones that were causing the issues. I'm sure as you mentioned that there are many, many more, but good to know the ones you listed.
Pro Tools 2023.3 Ultimate, Omni, I/O, Pre, HDX, iMac Pro, OS 12.6.5
https://soundcloud.com/jason-kalman
  #1262
Old 05-02-2019, 06:38 PM
arche3's Avatar
arche3 arche3 is offline
Slate is notorious imo for sloppy performances in protools. Steven claims otherwise. But it's pretty common when you remove slate plugins the system performs 25 to 50% better.
I use slate so I had to run through hoops for a stable system. Max ram. Dual high spec graphics cards for multi monitors pcie chassis for HDx. Vepro for VI work. The whole gamut of system upgrade. Take slate out and a stock max pro 5 1 works... lol.
Sent from my SM-G975U using Tapatalk
  #1263
Old 05-02-2019, 07:08 PM
amagras amagras is offline
This is true, every time I use the VMS my computer gets slow like never. I have to freeze and commit if I want to use his mics.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
  #1264
Old 05-02-2019, 10:43 PM
YYR123's Avatar
YYR123 YYR123 is offline
Originally Posted by Meads View Post
You can't expect them to work on fixes and useless crap at the same time, good Sir. Show some restraint.
Hahahahahahahahahahahahahahah
Daniel
  #1265
Old 05-02-2019, 10:51 PM
YYR123's Avatar
Default Re: Pro Tools 2019.5
Originally Posted by midnightrambler View Post
To be fair that thread is probably best avoided.
Really there’s a thread about PT2019?
Daniel
  #1266
Old 05-02-2019, 11:10 PM
Becharax's Avatar
Becharax Becharax is offline
I never knew there will be Pro Tools 2019 .... I thought it stopped at 2018 !
System Details:
iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
Apogee Thunderbridge/Apogee Symphony I/O 2x6
Eleven Rack/Focusrite ISA Two/Onyx 1640i
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Axiom AIR 49/Axiom 49/Yamaha P35
Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e
Genelec 8040b/Yamaha HS80s/M-Audio BX5a
Beats Solo/Shure SRH1840/Slate VMS
https://open.spotify.com/artist/7KfV..._branch=1&nd=1
  #1267
Old 05-03-2019, 01:38 AM
Simon2065 Simon2065 is offline
Just release this update, good bad or ugly so I don't keep looking at this thread
Simon2065
Pro Tools Ultimate 2023.12 Win 10 Pro 22H2 Gigabyte GA-Z270 i7-7700K 32GB Ram UAD Apollo 8
  #1268
Old 05-03-2019, 05:17 AM
the.engineer the.engineer is offline
Hahahah, so with you
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Pro 5,1 (Mid 2010) | 3.46GHz Six-Core Intel Xeon | 32GB Ram | AMD Radeon R9 280X 3072 MB | 256GB Samsung SM951 SSD Blade (PCIe) System Drive | 1TB WDC Sample Drive | 4TB RAID 0 Seagate Audio Drive | UAD-2 Quad PCIe
Sierra 10.12.6 | Pro Tools Ultimate 2018.10 | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
James Welch
Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire)
macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
  #1269
Old 05-03-2019, 06:07 AM
Basstian Basstian is offline
Default Pro Tools 2019.6
jic
Mac Pro 3,7 GHz Quad-Core Intel Xeon E5
Mac OS 10.15.7
ProTools Ultimate 2020.11
Video Slave 4.3.477
  #1270
Old 05-03-2019, 06:09 AM
BoRiZ KukoBa BoRiZ KukoBa is offline
Default Re: Pro Tools 2019.6
Originally Posted by Basstian View Post
jic
2019.5
Avid promises in May
Отправлено с моего iPhone используя Tapatalk Pro
Pro Tools 2018.4 Ultimate; Omni HD+HDX1 over Thunderbolt 2; MacPro 6.1
2019 features for pro tools vanilla ? cmbourget Pro Tools 2018 29 03-04-2019 03:00 PM
Namm 2019 jeffro General Discussion 2 01-26-2019 10:22 AM
Looks like at least 2019 before new Mac Pro K Roche Pro Tools HDX & HD Native Systems (Mac) 3 04-19-2018 06:44 AM
