Old 07-23-2015, 11:31 AM
jgiannis jgiannis is offline
Default Batch-Spot Multiple Clips to "Original Time Stamp"???
PT10 HD, Mac 10.7.5
Is there a way to batch-spot many clips to its "Original Time Stamp" all in one operation, rather than repeating the operation for each individual clip?
Below is the full situation I am in.
In my edit window, I have zero tracks. In my clips bin, I have 30 files (titled 1,2,3… 28,29,30).
In my "clip list pop-up" (drop-down button located above the "az") I ensure my setting says "Timeline Drop Order" "Top to Bottom."
Now, when I drag my 30 files into my edit-area (where there are currently zero tracks), 30 new tracks are created, one for each clip. Each clip ends up in its own track, and all clips are stacked perfectly vertically of each other. So far, this is what I want.
I can then go into Spot mode and highlight any of the 30 clips. Since each of my clips has an original time stamp, I simply select the original time stamp, and my clip goes to that time code. I can do this with each of the 30 clips, one-by-one, but that is very time consuming. Is there a way to batch-spot each clip to its time stamp all in one operation, rather than repeating the operation 30 times?
Old 07-23-2015, 11:47 AM
Drew Mazurek's Avatar
Default Re: Batch-Spot Multiple Clips to "Original Time Stamp"???
Nope. Been wishing for this for YEARS.
Submit on Ideascale I guess.
www.drewmazurek.com
Old 07-23-2015, 11:54 AM
YYR123's Avatar
YYR123 YYR123 is offline
Yes would be great
Daniel
Auto Spot to ORIGINAL time stamp instead of user? Maskeeper Post - Surround - Video 7 11-14-2022 09:10 AM
"Compiling" multiple sessions into one "Master" session. Any pointers? Nollykin Tips & Tricks 17 12-09-2013 10:36 AM
Spot to Original time stamp question oscarwonderboy Pro Tools 10 3 04-20-2013 04:17 AM
spot mode - original time stamp? 7.4 m-pow woodpigeonblue Pro Tools M-Powered (Win) 3 04-16-2009 01:41 AM
how to spot the inpoint of a region based on original time stamp? c-post Tips & Tricks 3 02-15-2003 12:07 AM
