#51
Re: Shift + fader sets level to 0db
Works on Mac
Cory Rizos, CAS Re-recording Mixer/Sound Designer Montreal, Quebec http://www.imdb.com/name/nm0007185/ coryrizos.com |
#52
I doubt it does work 100% of the time as it should.
Could you please specify your system setup? I have tried to make it work on several different Mac OS X configurations. Eucon-version:?? OsX-version:?? Network settings:?? (DHCP or Static IP, Routing?) Mac Hardware:?? DAW:?? |
#53
In case this helps to solve the problem, here are my findings:
If you shift-touch the fader really fast (your touch is very quick and light), it works. If your touch MOVES the fader when shift-touching it, even slightly, or the touch lasts longer than a fraction of a second, it doesn't work. In this case, the DAW (in my case Logic) still registers it as shift-touch and the fader in the UI moves to 0db. The physical control surface fader does not move. EUCON v3.2.2 Static IP, connected directly iMac late 2013 Mac OS X 10.10.2 Logic Pro X 10.1.1 |
#54
In my setup with Cubase Pro 8, (8.0.10) - same findings. Interesting - with EUCON v 2.7.1 this functionality is given without problems Cheers
**************************************** ALSTUDIOS REGENSDORF SWITZERLAND [email protected] https://sites.google.com/site/alrecordingstudio/ 1pc AVID Artist Control and 1pc Euphonix MC Mix Win11 64Bit, Cubase Pro 12.0.52 **************************************** |
#55
BTW, I couldn't find an Ideascale entry for this specific issue, so I created one. Vote for this, if you think it should be fixed:
http://protools.ideascale.com/a/dtd/...le/162686-3779 |
#56
#57
I have noticed that it works some of the time, I'm not exactly sure of the conditions. So, I don't really buy into the idea that it was broken on purpose, more like it's just another bug
#58
You're right it's a bug.
#59
Bounce!
#60
Re: Eucon 3.3 and again, the lack of requested features.
What’s Fixed • Shift + Fader touch does not set fader to 0dB (EUCON-2883)" So, despite the promises, it still doesn't work? (haven't yet updated myself) |
Shift+fader touch= wtf!?!?! | C52382P | Artist Series | 3 | 04-23-2015 02:51 AM |
Eucon 3.1 bug with McMix: Shift-Fader doesn't work | DhyanMikael | Artist Series | 5 | 12-24-2013 04:50 AM |
VCA Fader Level | Jstil | Pro Tools TDM Systems (Mac) | 7 | 04-28-2011 12:21 PM |
Fader bank shift changes on screen location | The Tonic Room | ICON & C|24 | 3 | 07-29-2008 10:10 AM |
"Shift" command not affecting VCA fader automation | Matt Chan | Post - Surround - Video | 2 | 12-15-2006 06:24 PM |
