Old 02-26-2012, 05:28 AM
klyg klyg is offline
Default no plugin screen that appears in PT10.0.1 OSX Lion with MC control v2 encoder
Hi when i use v-control (v2) encoder to instantiate a plugin in PT10.0.1, in OSX Lion, there's no plugin screen that appears in PT10.0.1
previous version 10.0.0 did not have this problem
I tried to reinstall the update (10.0.1) and it sometimes solves the problem
but imediatly after using PT 10.0.1, the problem reappears !
Tried also repair the disk permission, still same problem.
don't know what to do,
Please Help !
OSX lion
MC control+mix = last drivers
PS: No problem with i7 PC PT10.0.1
Cheers !
Old 02-29-2012, 10:43 PM
Default Re: no plugin screen that appears in PT10.0.1 OSX Lion with MC control v2 encoder
After AVID's suggestions (cf links) that work but need to be repeated everytime i re-open PT,
I just discover an interesting point:
whithin an PT session opened,
in eucontrol setting,
when changing the order of my surfaces,(I used to have MC control first, then MC mix, so changing the order do it)
then the plugins instantiation screens on my mbp works !
Really odd, but works !
PS: I checked my network config, my MBP and all my artitsts controllers are hard networked (rj45) in the same router (Airport Extreme, acting as my WIFI router too), and the AE is hard networked (rj45) to my ADSL.
Any suggestion ?
Best R.
Cheers !
Old 02-29-2012, 10:51 PM
Thumbs up Re: no plugin screen that appears in PT10.0.1 OSX Lion with MC control v2 encoder
just want to mention that in LOGIC 9 everything is smooth. Plugins instantiation through artists control and mix is great !
Cheers !
Help! Mountain Lion PT10 plugin menu issue giltzer14 macOS 3 08-29-2012 03:04 PM
2.6.1 Rotary Encoder Issues, and MC Control Touch Screen Freeze anotherchrisperry Artist Series 12 05-04-2012 01:45 AM
v control (v2) plugin encoder cannot instantiate plugin screen in PT10.0.1 klyg Artist Series 2 02-29-2012 10:50 PM
Following power outage the 11R screen no longer appears World Spirit Eleven Rack 3 01-20-2012 03:39 PM
Avid store appears to be down/lagged... must be all those people NOT buying PT10 ;) Dism Pro Tools 10 13 10-20-2011 11:00 PM
