#81
Re: 8.01 bugs
Hello ?? Anyone ?
#82
Re: 8.01 bugs
Paul -
Again, sorry for the delay. Lots going on here and it took some time to get info from Magma about which model chassis you actually have. It seems like it may be compatible. So let's move on. Can you tell me the following: 1. Number and types of drives attached and which ones you're using for sessions. 2. Any attached peripherals (to the computer) and which port are they attached to? 3. Slot order in the computer 4. Slot order in the chassis Then, try the following: 1. Remove all Process cards, trash prefs and test again. 2. Move the host card to a different slot in the computer, trash prefs and test again. Let me know if either of those change the problem/symptoms. |
#83
Re: 8.01 bugs
I actually couldn't wait anymore and couldn't work like that.
So I bought a new mac, a new chassis and all my cards are with Digi right now, going over them to make sure nothing's wrong with them and to make sure that they're all in sync. |
#84
Re: 8.01 bugs
Had a nasty one today. Change an oxford eq parameter . It modifies all 100 instances of them in one go. turn on filter, all eqs get a filter.
That might be a cool idea but under a deadline it wasn't funny at all. Haven't found the exact cause but I'm going to dig into that one and post back here. |
#85
Re: 8.01 bugs
As in group attributes you can link inserts between tracks that share the same plug in so 1/ if the all group is on 2/ if insert a link is on (or b or or d etc) 3/ you adjust one oxford then you are actually adjusting all on the same insert May not be your issue but could be |
#86
Re: 8.01 bugs
Interestingly we tried restore and flatten midi today and flatten seems to have stopped working in 8.01cs1 that I'm using
#87
Re: 8.01 bugs
Somehow my globals by default now have insert a controls and bypass enabled. How that came to happen is beyond me. That was really scary So this one is on me. Sorry guys and thanks Sirpucho for the quick reply. Now I have to figure out how to make sure this never happens again since it seems to be enabled by default. Though I can see that this could be quite useful at times even if moves are not relative but absolute. (Hipass everything but bass and kick at 200hz in 3 clicks) |
#88
Re: 8.01 bugs
Glad to report that my new system is A Okay,, Working like a charm...
Just had to cash 5k.. That's all ! |
11.1.2 on Mountain Lion bugs bugs bugs. command+f, elastic audio, discoloration | farmfresh | Pro Tools 11 | 21 | 05-01-2014 07:21 PM |
PT8 bugs | murergobben | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-24-2009 04:07 PM |
Bugs in my box - no, REAL BUGS !!!!!!!!! | Mixtrix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-25-2006 06:33 PM |
Old, old bugs | Pete Gates | Tips & Tricks | 2 | 02-14-2006 09:10 AM |
Bugs on 5.3.1 | Captain_Pants | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-24-2002 11:13 AM |
