Old 04-04-2009, 05:11 PM
lxaudio lxaudio is offline
Default VC-1 video codec
Hi !
I'm going to receive in a week 8 video files that I have to use to record the voice-over. And mix it.
The problem is that the video is encoded with a VC-1 HD codec.
Is there a hardware or software solution that can integrate in Protools (preferably) so that I don't have to convert the video file to DV?
DV is what I need to export through firewire to a Canopus straight to tow TV's.
Can anyone help? Is this even possible?
Thanks,
Sérgio
Sérgio
Old 04-04-2009, 08:20 PM
JC925602 JC925602 is offline
Default Re: VC-1 video codec
To play VC-1 through a Canopus ADVC 100 you have to convert it to DV. To convert you need QuickTime Pro and Flip 4 Mac player pro.
If you don't want to convert it, you can buy a Video Satellite and hope it work well with the VC-1 format and if it's not working, go back to the convertion process.
JC
Old 04-05-2009, 02:45 AM
Thanks for the reply!
That would take a loooooong time, wouldn't it? Because these video files are in HD (I think canopus ADVC 100 only accepts SD, isn't it?), so they are huge! I think for this specific client it's going to be the norm from now on.
Have you heard anyone that is successful with a video satellite and VC-1 video files?
I emailed decklink and they don't have any solution that would help me.
Thank you very much!
Sérgio
Old 04-05-2009, 08:05 AM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
I guess the question I have is , why??
Old 04-05-2009, 08:45 AM
It all depend on your system. And you don't have to wait that QuickTime player finish one job to start another. You can export all your files then go to sleep. The next morning everything should be ready.
Ask your client for an exemple file so you can do tests. AFAIK VC-1 is a codec like H-264 and was built by Microsoft because they were afraid of not being in control of every file standard and didn't want to see a video standard exist outside of WMV framework.
Codec like H-264, MPEG, and VC-1 are not well-suited for use with ProTools because each frame is not self contained. It's OK if you only play it forward, but if you rewind a little bit you will see big pixel, blurry image and the computer will take some time (until the next KeyFrame) to get all the data.
Only SD and only in DV format.
I was asking myself the same question. Your client is probably working with uncompressed video and is exporting the finished product to VC-1.
Maybe he selected VC-1 just because someone told him that it's the way to go, without any specific needs to go to VC-1 (maybe a religion war between H-264 and VC-1) then you should ask him to export to DV (SD, not HD).
And your client should send you media that you can use, if not, charge for the time you take for the conversion. And, at the end, send them the audio in a compressed format that require them to buy an extra software to use it
JC
Old 04-06-2009, 02:23 PM
Thank you all for your help.
My client is an Authoring house and they'll be doing a Blu-ray. Their client is sending them the program already encoded. So that's what I have.
I'll just have to decide if I convert and charge or if it is going to be such a hassle that I better ask them for a DV version of the program!
Anyway, thanks to all of you!
Sérgio
Sérgio
Best video codec for 11? Kasper Post - Surround - Video 90 01-22-2014 10:46 PM
Best video codec to use with PT11 Intransit Pro Tools 11 2 01-13-2014 11:56 PM
PAL video codec for PT HD 8.1 on a PPC Mac Larold Post - Surround - Video 8 09-24-2011 10:05 AM
best video codec for pt (survey) hitp Post - Surround - Video 19 07-30-2011 03:31 AM
jpeg A video codec villagesound Post - Surround - Video 5 07-25-2007 08:15 PM
