Old 09-07-2007, 01:14 PM
proverb18 proverb18 is offline
Default Duplicate MIDI notes with AXIOM 61 problems
Hey all,
I was using an older Roland keboard for all of my VI work and decided to upgrade my controller to the AXIOM 61 which btw works and feels great. Ever since switching I will go to record MIDI parts and on playback I have issues because every note gets recorded twice. The first note is a very short note that looks like an indicator of some kind(I checked PT PDF and not much was said about the little "X" note), and then the 2nd note recorded is the right one......length, velocity, everything. Because of this, I have to go in to the region and get rid of all the little notes that are in front of each correct note before the region will play correctly. Has anyone else ran into this with the AXIOM series or any other keyboards? I HAVE TRIED THE REMOVE DUPLICATES NOTES FUNCTION, and it only removes the 2nd "correct" notes. Any idea's????
Much Thanks
Shawn
(I did post this in the MIDI group as well, no luck yet)
Old 09-07-2007, 01:30 PM
Carl Kolchak Carl Kolchak is offline
Default Re: Duplicate MIDI notes with AXIOM 61 problems
Is this what you mean?
Here is Digi's response.
Old 09-07-2007, 02:43 PM
not so much, I am running 7.0 (maybe 7.1?) I will look into that vid more at home, I am at work now......thanks though!
Shawn
Axiom 61 recording duplicate notes in Pro Tools MP 8.0.3 StudioRat81 MIDI 7 02-26-2015 08:17 AM
Duplicate MIDI notes? Monaco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-08-2013 01:29 PM
MIDI Editing duplicate notes AMcG Pro Tools 9 1 10-26-2011 07:28 AM
Duplicate MIDI notes with AXIOM 61 problems proverb18 MIDI 0 09-07-2007 09:56 AM
How do I remove duplicate MIDI notes? Rob Ruce 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-11-2003 02:51 PM
