after 6 hours of recording, I had nothing!!!!!
"Soe audio files were removed because the files they referred to were too short"
What is that?? Whatever this error is just cause me about 12 hours of my time seeing how it took me 6 hours to record everything the firdt time. I recorded a session it my normal way that I do, and I closed the file. When I opened the session back upm it was empty, as in NO AUDIO WHATSOEVER! ANYBODY HAVE A CLUE! YOUR HELP WILL BE MUCH APPRECIATED!! |
Re: after 6 hours of recording, I had nothing!!!!!
Tell us about your audio drives... which format, how are they hooked up to the PC and if FireWire, which card?
Rail
I hope i answered your questions. |
Sounds like a few issues... a) get an approved FireWire card (an Adaptec 4300 works great), b) use an external FireWire or internal separate IDE drive, what's the DMA status of the disk controller in Device Manager (search the DUC and AnswerBase for DMA)?
Rail
www.xeetstreetband.com Intel 486 75Mhz - 16Mb RAM - Audiomedia III - Session Software |
I have the adaptec 4300
Problem goes away after restarting the computer.
Is this a known bug in 6.4? This has to be fixed. |
Haven't heard of it before ... sounds system related.
Start recording to a separate drive. Rail
I stand corrected. the problem came back!
When I initially restarted I recorded some audio , saved - and closed the session. When I reopened, the audio was there. However once I continued to record -I repeated the same steps, and again, all my audio was gone. However every track is still in the audio files, just not on the tracks like they should be. How can this be. I didn't change ANY other settings. I record once and it's fine. I record again, in it's nothing!! My family's well being is depending on me getting THIS PROJECT done! |
i have this problem too. its been going on a month or so and is really annoying. it started after i reinstalled windows and pt6.4. i went through all the instructions i could find for adjusting settings etc but it still happens. if you consolidate the regions before closing the session it may help. it works for me anyway. if you do a search of this forum for "some regions were removed" it will bring up another thread by King Fish whos also had this problem. there are a couple of other threads too but i cant find them. not much help to be found though, unfortunatly.
Recording in LE for 2 hours strait | jnewry | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-12-2010 07:11 AM |
Nonstop recording. How? 4.5 hours+ | SlowTools | Pro Tools TDM Systems (Mac) | 48 | 10-04-2008 03:08 AM |
All recording done in the past six hours vanished! | kiddakota | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 08-29-2006 11:07 AM |
Recording live 3 hours!! | fabpab | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-10-2005 05:01 PM |
So why was the DUC down for 4 hours? | Swaphappy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 09-08-2002 11:34 PM |
