  #1281
Old 05-03-2019, 10:41 PM
capt kirk capt kirk is offline
Default Re: Pro Tools 2019 !
if you NEED 1024 midi tracks to write a song or to do something creative, theres another business for you, where utter lack of creativity abounds, its called the government.....why not 10,000 midi tracks, think of the musical genius that'll be revealed, with each thousand more midi tracks.......wow....
www.kfaudio.ca
  #1282
Old 05-04-2019, 12:55 AM
TrentWilliams TrentWilliams is offline
Have you ever scored a feature .. ?
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • DockMac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
  #1283
Old 05-04-2019, 02:39 AM
jasonkalman jasonkalman is offline
So you would/could actually use 1024 midi tracks? I mean I get it a feature (assuming movie or TV) would use a lot of midi tracks but 1024? I had no idea. Clearly I'm not in the movie/tv business. That seems like an awful lot of midi tracks. Someone heard and listened to the need at Avid.
Just curious what is the max number of midi tracks you've had to use on a score?
Pro Tools 2023.3 Ultimate, Omni, I/O, Pre, HDX, iMac Pro, OS 12.6.5
https://soundcloud.com/jason-kalman
  #1284
Old 05-04-2019, 03:28 AM
andreªs andreªs is offline
It's all about setting up templates in order to have a wide range of sounds right at your fingertips for instant use in a session. It's an absolutely common workflow set-up especially when scoring with Cubase. You never will use all those tracks at once in a cue...
  #1285
Old 05-04-2019, 05:13 AM
JCBigler's Avatar
JCBigler JCBigler is offline
I thought feature films were still using live orchestras. 1024 MIDI tracks sounds like independent films that can't afford to hire real musicians.
Justice C. Bigler
www.justicebigler.com
Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB
2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio
Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre
Road/hotel: Roland OctaCaputre / Apogee One
  #1286
Old 05-04-2019, 05:34 AM
LDS LDS is offline
I don't think it matters. At some point all of those scores are going to be written and arranged using DAW based workflows well before any real musician is even booked.
  #1287
Old 05-04-2019, 09:24 AM
BScout BScout is offline
No.
The mockup is still done in MIDI and in-depth MIDI at that
Not to mention there's a wide variety of synthetic sounds, obscure percussion, and ethnic instruments that are left in the final score even with real orchestra. Templates can have 300 MIDI tracks devoted to different types of metallic hits or pads alone; a lot of those custom built/recorded "instruments." If you see someone like Alan Silvestri, John Powell or Hans Zimmers full templates, you'll see hundreds of tracks -- however hiding the unused groups of MIDI template tracks is pretty common.
And that kind of palette also takes up more MIDI tracks in a template. Cubase and Logic have been handling this well for A list composers. Pro Tools has been awful at this which is why expanding MIDI is/was needed.
The small-minded people railing against this as "not being creative" just lack imagination of what the workflow is like for others (professionals.)
  #1288
Old 05-04-2019, 10:06 AM
Originally Posted by BScout View Post
No.
I for one have no idea what the professionals you mentioned do to turn out top-notch film scores. Seems they did it fine before there was midi, some of the dudes you mentioned were writing killer scores in the 80s. But if 1024 is a good number (seems rather random to me....why not 1150?) for the .000001% of PT users, i'm all for it . Meanwhile I can't get 5 VIs to work with PTs without having to freeze track everything. I assume these professionals don't use PTs for the heavy VI lifting, which it is not capable of, but rather load the stems from another DAW, or I should say their interns do.
  #1289
Old 05-04-2019, 10:33 AM
JingleDjango JingleDjango is offline
In a binary system, a lot of things boil down to powers of 2. Hard to know the exact reason in this case.
  #1290
Old 05-04-2019, 11:23 AM
1024 because 2^10
The industry has changed since the 80s. As have budgets. As have expectations by directors and producers on mockups.
When you have thousand midi track templates, you aren’t using a single system DAW. No DAW can run thousands of instruments (processing and RAM)— you use a host and multiple computers to distribute instruments. Hans Zimmer uses a custom/proprietary host software over many computers (14+) to feed his DAW. Powell/Silvestri/most composers use Vienna Ensemble Pro over many computers.
But you still need the MIDI tracks in your DAW to trigger these other computers.
2019 features for pro tools vanilla ? cmbourget Pro Tools 2018 29 03-04-2019 03:00 PM
Namm 2019 jeffro General Discussion 2 01-26-2019 10:22 AM
Looks like at least 2019 before new Mac Pro K Roche Pro Tools HDX & HD Native Systems (Mac) 3 04-19-2018 06:44 AM
