#21
Re: 8.01 bugs
I've done all possible hardware-checks...all my hardware is just fine.
Thrashed prefs and databases several times and even reinstalled 8.01....no result. Disabling DSP cache will not solve problem There's no connection in trackcount or incompatible plugins ( digi techsupport utility tell me all plugs are fine) Little sessions, big sessions...they all crash on close... Its evident to me that problems have started since i updated to 8.01 For sure...8.0.1 sucks and i'm going to downgrade to 8.0cs3 as soon as i'm able to.I'm done ! cheers |
#22
Re: 8.01 bugs
i have tried everything today at work and still crash on close.
i don't even know if i can go back to 8.0.cs3 cause i updated so many plugs. between crashing and dealing with the scrolling issue i'm not getting a warm fuzzy feeling at all. i have unplugged drives/repaired permissions/ran digi test. nothing helps. Digi, ya gotta weigh in on this one. zeeman |
#23
Re: 8.01 bugs
PT HD 8.01 still sucks with Expansion Chassis HD!!!!
DIGI - please solve problems with this device in last supported version. Today - the best working version with Expansion Chassis - 7.4.2 cs3. Mac Pro 8-core. 6 gig Ram, PT HD 8 cs3, Expansion Chassis HD, 1 process, 3 Assel cards, 192 interface, PT LE 8 with Imac 24 & MBOX2 pro. |
#24
Re: 8.01 bugs
Is this a bug or is this a setting ? On 8.0.1
When I click a track to export it then hit command shift K to export it, before it would just export that track (asking me where to of course). Now I have to open (slide open) the files track list (to the right of the session) and make sure the track I selected in the session is the same one selected in there. More than often it's not. I keep forgetting and I keep exporting the wrong tracks.. It's so damn annoying. Another annoyance... When I turn on or off groups in the mix window, they used to follow in the edit window. Now they don't even though I have Link Edit/Mix Groups Enables. It used to be linked. When I switched in edit or mix, it would follow. It' driving me crazy. Otherwise, of course I got the crashes on some songs, I reboot and it launches fine, then ext day same thing. I'm just getting used to it. So are my clients... Digidesign for how long ? Oh and I still have my record problem where 1 out of 10 times when I go into record, it just doesn't go, it plays... I contacted Tech Support over the phone, siad they'd get back to me, still haven't 2 weeks later. I gave up. |
#25
Re: 8.01 bugs
Another one to add here...we have three HD rigs in our facility running 8 and all report that with video in a session, you hit the space bar and about 75% of the time the video will play. The other times it just doesn't seem to catch.
This morning I'm having to hit play 4 and 5 times at times for the video to go. Calgon E take me away. |
#26
Re: 8.01 bugs
Today i trashed 8.0.1 and it's prefs.
Reinstalled 8.0cs3 Still crashing on sesssion closedown i don't understand because i'm convinced the 8.0cs3 was flawless waiting for my copy of diskwarrior4, it's my last hope.... |
#27
Re: 8.01 bugs
We've identified a possible issue with ReVibe when using DSP caching that could cause crashes.
If you disabled DSP cache and still encounter problems, it's something else. |
#28
Re: 8.01 bugs
If you used a software utility to test RAM, I can pretty much guarantee it's not going to show you if RAM is bad. I have yet to see a RAM test utility come even close to being 100% (or even 10%!) accurate. I, personally, wouldn't rely on them, ever. You should definitely try swapping/replacing RAM - if everything you're stating is correct, RAM is highly suspect. Quote:
Is that what you did? Could you please post your installed plug-in version list, just so we can double check? Quote:
#29
Re: 8.01 bugs
Elastik.dpm Version 1.5.2.3 (questionable) MOTU Ethno Instrument (very questionable) MachFive2 RTAS.dpm 2.0.1 (very questionable) Phoenix.dpm 2.1x3 (outdated, install version 2.4.3 or higher) SteinwayRTAS.dpm 7.3x0 (incompatible, as it's based on a known incompatible old Kontakt player. You should download the Kontakt Player 3.5 from NI and use that to load the Steinway libraries) You also have both the Stereo and Stereo Dithered mixers in your plug-ins folder. You should remove one or the other - having both in there can cause instability. Do you know which version of the TC MasterX3 plug-in you have installed? It doesn't show in your list - you need 4.0. VW_PCM96 - I don't recognize this plug-in. Can you tell me the manufacturer? I'm assuming you're not using any of the plug-ins in the Plug-Ins Unused folder, yes? There are several incompatible ones in there as well... Quote:
I also need to know which specific ATTO model this is - using a compatible one is critical to stability. Given the number of incompatible plug-ins and other configuration issues I'm seeing, it's likely that all your problems stem from them, rather than 8.0.1 itself. |
#30
Re: 8.01 bugs
11.1.2 on Mountain Lion bugs bugs bugs. command+f, elastic audio, discoloration | farmfresh | Pro Tools 11 | 21 | 05-01-2014 07:21 PM |
PT8 bugs | murergobben | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-24-2009 04:07 PM |
Bugs in my box - no, REAL BUGS !!!!!!!!! | Mixtrix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-25-2006 06:33 PM |
Old, old bugs | Pete Gates | Tips & Tricks | 2 | 02-14-2006 09:10 AM |
Bugs on 5.3.1 | Captain_Pants | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-24-2002 11:13 AM |
