Old 07-30-2018, 03:07 PM
veinticinco veinticinco is offline
Default "Yes to all" command for clearing Clips
Hello everybody
Is there some command or procedure to clear clips from the clip list without having to confirm every single clip selected?
My procedure until now is the following:
I work in post production for TV and there are thousands of clips in my clip list at any given time. Once I finish my mix, I try to clean up the session by going to the clip list menu and click "Select Unused" and then Clear selected.
Here is where a popup window asks if I'm sure, and it does this for EVERY SINGLE ONE of the clips selected. It's a very boring and time consuming to click YES hundreds of times
I've tried clearing the undo queue, selecting small groups of clips at a time, and my last resource is to close the session and open it back up. This is not great because post production sessions are gigantic and take a very long time to open.
Its not the end of the world, and I've been doing (and loving) post production work on Pro Tools for 8 years now (this has been a question of mine forever), but if any of you know a better way or the right way to do this I'll be very grateful.
(Sorry for my English, I'm Colombian and English is my second language)
Pro tools 2018.4 on MacOS 10.13.5
Old 07-30-2018, 09:02 PM
BScout BScout is offline
Default Re: "Yes to all" command for clearing Clips
Hold "Option" key down when clicking to clear selected.
Old 07-30-2018, 09:53 PM
its2loud its2loud is offline
To be a little more specifc, when it asks you “are you sure” hold down the Option key while you click on “yes” with the mouse.
Old 07-30-2018, 10:42 PM
Whoa!
It works as expected! Thank you!!
Old 07-30-2018, 10:45 PM
Nope. You can skip that these day.
When the dialogue:
[Cancel] [Delete] [Move to Trash] [Remove]
comes up, option+click Remove. You do not have to go to the "are you sure stage"
Midi Clips View Problem, option + "-" keyboard shortcut broken kingtinker Pro Tools 10 5 09-25-2016 01:47 PM
"Application Not Responding" When I Separate Clips in Pro Tools 10 Red Door Recordings Pro Tools 10 3 08-11-2015 02:43 PM
Batch-Spot Multiple Clips to "Original Time Stamp"??? jgiannis Pro Tools 10 2 07-23-2015 11:54 AM
Wrong "auto-rating" of clips during loop recording joachim Pro Tools 11 5 02-10-2015 11:58 PM
Is there no way to say "Yes to All" when clearing audio? jlnelson19 macOS 4 04-22-2011 08:19 PM
