Midi echo or duplicate notes HELP
I have searched through the forums trying to find out why I am getting two notes for everyone one I input through my midi controller keyboard. I have worked out how to get rid of them (event-remove duplicate notes), but it is really annoying as an event after the fact.. The threads about this show someone has accidentally put a midi cord in and then out again, causing the midi echo. This is not the case here. In fact, this anomaly only just happened recently. I've had the same setup & same controller keyboard (Roland RD-700GX). I've explored all midi options on the out of my keyboard and all options on the midi input (M-Box). Please help, as this is wasting so much time each session?
Simon Reich Model : ASUS All Series ASUS MB Mainboard ASUS Z97-A BIOS : AMI (OEM) 0902 05/08/2014 Intel vPro : 9.01.01.1000 Total Memory : 16GB DIMM DDR3 Processor : Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz (4C 3.9GHz, 3.9GHz IMC, 4x 256kB L2, 6MB L3) Operating System Windows System : Microsoft Windows 7 Personal 6.01.7601 (Service Pack 1) Platform Compliance : x64 |
Re: Midi echo or duplicate notes HELP
Welcome to the community.
USB or MIDI connection? Both? Have you possibly enabled another overlapping zone on the keyboard, thus sending two notes for each key press? Have you tried a factory reset on the keyboard?
If in your MIDI input select field, you have it set to All,
go into your midi studio set up and assign your specific keyboard, then in MIDI input select on your track, select the instrument you created and a specific channel and you should be good. e
ihatetyping |
I had this happen when I was using a Roland TD-10 kit. Turned out that having MIDI cables connected both ways(so MIDI came back while recording) was the cause(unplugging the returning MIDI cable solved that one)
On my Yamaha Motif 7 I have both the MIDI out and input connectors connected to my Motu MIDI Timepiece AVUSB. What I did/do is to turn off local on in the Yamaha's setup.
Oddly enough, my Motif es8 has no problem on this
Does a keyboard factory reset wipe all your sounds & presets in the Roland RD 700GX?
It won't wipe anything that was originally in the keyboard from the factory. It will erase any custom sounds and presets you may have entered.
I just tested my Pro Tools setup with a different controller keyboard & it is doing the same duplicate notes scenario. This is driving me nuts now!!! I know it is not midi echo, because I don't have a return cord sending two notes to Pro Tools & I now know it is not the controller keyboard that's doing it. So what setting in Pro Tools would be adding an extra note to my inputs?? As I said above, it never did this before & has only surfaced since my move from one room of my house to the other. HELP PLEASE!!!!!
Duplicate MIDI notes? | Monaco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 10-08-2013 01:29 PM |
MIDI Editing duplicate notes | AMcG | Pro Tools 9 | 1 | 10-26-2011 07:28 AM |
Duplicate MIDI notes with AXIOM 61 problems | proverb18 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-07-2007 02:43 PM |
MIDI ghost/duplicate notes problem...HELP! | vocalvoodoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-02-2005 08:12 AM |
How do I remove duplicate MIDI notes? | Rob Ruce | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-11-2003 02:51 PM |
