Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 12-23-2018, 10:35 AM
bayside bayside is offline
Default Bussing problems
I'm having problem bussing to an audio trk. I can bus to an aux but not a audio trk. I'm doing sub-mixes. What could be up? thanks
Old 12-23-2018, 11:06 AM
Default Re: Bussing problems
Could you give less info? Its likely operator error(which is good, because that's the easiest thing to solve). Maybe post a screen capture?(or upload a hi-res photo and link to it as this site tends to shrink pictures, which makes it hard to see detail, like bus names)
Shooting from the hip; you are routing to an AUDIO track, but have you set that track to INPUT monitoring?(the green button with the "I" in it)? Without doing that, you will not hear that track's input unless you actually put it in RECORD and roll the track.
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 12-23-2018, 11:46 AM
Green button with an"I" in it I'm not seeing.
Old 12-23-2018, 12:01 PM
And if you bothered to tell us your version of Pro Tools we would have a clue if you should be seeing an “I” button or not.
Old 12-23-2018, 03:52 PM
That^^^ Or try recording and see what happens(see why details matter?)
Old 12-24-2018, 05:42 AM
Doing a little detective work (shouldn't have to do that) I found in this thread http://duc.avid.com/showthread.php?t=402140 in post #5 the op says he's running this config:
System;
MacBoxPro 10.8.5
PT 11
Artist Mix
Avid keyboard
2 Apollo 8's
blue tooth mouse
Which means he won't have the green button with the 'I' in it.
Trying to make sense of his original post here seems to me to say not that he can't hear the audio but that for whatever reason he can't bus from an aux to an audio track. I wonder if it's a mono/stereo thing? Is he trying to go to an audio track that already exists or to a new audio track? Either case I'd suggest the op try this: in the output selector for the aux track select 'new audio track' to route to and see if that works.
Jack
QAPLA!
Old 12-24-2018, 09:11 AM
System;
MacBoxPro 10.8.5
PT 11
Artist Mix
Avid keyboard
2 Apollo 8's
blue tooth mouse
This is the system I'm using.. . . . ah, if I put the track in record there's a signal present and I can record. Solved for now.
Old 12-24-2018, 09:48 AM
You need to play with track > Input monitoring/auto input mode to monitor inputs. Described in the Pro Tools Reference Guide. Track input monitoring (the “I” button) is in Pro Tools HD and was added to Pro Tools standard later in a 12 release.
Old 12-24-2018, 10:52 AM
Thing is bayside is running PT11 vanilla and not HD.
Jack
QAPLA!
Old 12-24-2018, 11:51 AM
Okay, now we know the limitations of the system. Here's a work-around to use until you move to a new version(someday). When you create your Audio track, create an AUX track at the same time. Set both tracks to the same input buses. Audition with the AUX track. When you are ready to print, put the AUDIO track in record, mute the AUX track and roll transport.
Bussing VS Insert Problems BPRmusic macOS 50 01-28-2015 01:53 PM
Help a New Guy with Bussing in PT 8 PMcC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-30-2010 01:30 AM
problems bussing LIVE into PTHD 8 workhouse Pro Tools TDM Systems (Mac) 1 08-20-2010 12:44 AM
I'm New to "Bussing" lastminute 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 11-16-2005 02:58 PM
Phase problems when bussing Terminal Pro Tools TDM Systems (Mac) 2 09-14-2001 09:23 PM
