Old 08-19-2014, 05:44 AM
stizz0 stizz0 is offline
Default Avid HD I/O Issue - Will not Connect With HD Native
Got OSX 10.6.7, HDPT 8.5 .... HD Native PCIe card
on a 2 X 2.4 Quad core Intel Xeon macpro (2011 I think)
2 x HD IO both stay in 'orange ring' mode on powerup and PT loading.
PT gives the ol:
"Unable to Find an Audio Interface attached to the first HD card. Check power and Digilink cables.
Digidesign coreaudio manager shows HD Native, but no periph connected
'N' at PT startup gets to playback engine and the current engine is Pro Tools HD Native
Checked and reseated Digilink cables.
Changed PCI slot of card.
Digitest passed the card, but Audio I/O Firmware shows
----- "Firmware Version in Selected Device" and Updating
ends in errors at 0% done.
Error message is:
Data verification error on flash sector 0
Slot Info tab, in the digi utility, shows it knows something is plugged in but
under Peripheral Name: there is "Firmware Missing"
Tossed Prefs, ran cleanup app, zapped PRAMM.
Reinstalled everything numerous times.
Tried selecting Native in sound prefs and playing itunes.
This resulted in a digi core audio failure and error (in the crash report)
And sound prefs was double checked to not have Native HD selected
as system output until this test.
It seems a firmware issue happened somehow but on both IO's?
How would I go about resetting firmware on the HD IO's?
Could it be core audio drivers?
Could the HD IO's just up an die?
ANY ideas or suggestions would be much appreciated.
Old 08-19-2014, 06:50 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Avid HD I/O Issue - Will not Connect With HD Native
Have you tried another DigiLink cable? I see you have two HD interfaces so you absolutely have two cables too. First try to get one interface up and running, either one would be okay, and if one of the boxes connect with one of the cables, then we can go shopping cables. If not, this will get more tricky...
Janne
Old 08-19-2014, 07:01 AM
Hi J!
Firstly, THANK you for the quick reply.
This is a client I would really like to keep happy.
Yes, we do have 2 cables at the studio and initial testing
to isolate issues, we swapped cables and IO's in all configs.
Both HD IOs exhibit the same "firmware missing!" issue
when either is wired with either cable.
Onto tricky, Im guessing....
Old 06-05-2016, 01:43 PM
Marco Bernardo's Avatar
Marco Bernardo Marco Bernardo is offline
I just got the firmware missing issue today.
Now my HD Omni is on Orange state when it's on, and I can't do anything.
HELP!!!!!!!!
Thank you
Marco Bernardo
Dialog Editor, Sound Designer, Re-Recording mixer
nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro
Old 09-13-2020, 12:07 PM
djdus djdus is offline
i am having this same problem and the digitest says the firmware is missing from the hdio, did u all ever figure out how to fix this??
HELP!!!!!!!!
Thank you
HD Native can't connect with Omni Jace Everett Pro Tools HDX & HD Native Systems (Mac) 6 05-10-2012 03:47 PM
Record Native Instruments w/ Direct Connect and MIDI jeffreyr Digidesign Hardware & Software 0 07-11-2003 02:54 AM
Direct Connect from Native Instruments (Finally..) yavuzj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 37 01-24-2002 11:41 AM
What is Direct Connect from Native? finalcut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-23-2002 11:22 PM
Native Instruments: Direct Connect versus RTAS?? tommydee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-27-2001 06:00 PM
