Old 10-28-2020, 02:51 PM
Toys Toys is offline
Default ProControl, PT 9, on Win 10, I/O Motu 828
Just trying to kick it down the road a little farther.
It will occasionally work.
These are the most common error messages.
on start up
Unable to read Location 0x00380045
0x78302044
0xFF534758
0x00000000
Could not create a new document because Pro Tools could not
set sample rate to specified value..
If it allows me to enable ethernet controllers I sometimes get an out of memory error.
Thoughts?
Old 11-01-2020, 02:49 PM
Default Re: ProControl, PT 9, on Win 10, I/O Motu 828
2 new error messages
Unable to read Location 0x002D0036
and a runtime error for R6025
-pure virtual function call
Old 11-01-2020, 03:25 PM
Not sure why you are posting/what you expect here.
Pro Tools 9 ancientware was never designed to run on Windows 10.
The Pro Tools compatibility information is documented here: https://avid.secure.force.com/pkb/ar...tibility-Chart
Not being officially supported would be a good reason to give up, and you are unlikely to find folks here to hold your hands trying to make this work. There are some old threads on DUC about getting Pro Tools 8 or 9 running on Windows 10 that you can look for.
Not that it will likely help you much in this case but basic troubleshooting and the kind of information you should supply if seeking help on DUC is under the “Help us help you” link up the top of each DUC web page.
Old 12-21-2020, 08:59 AM
Indeed^^^^ You might consider moving to a modern version of Pro Tools and then adding the Nyrinck program that allows the ProControl to still function as a HUI device
[IMG] code is Off
ProControl with 7.0/7.1 LE (procontrol.dll etc) eccles ProControl, Control|24, Command|8 0 09-17-2010 12:06 AM
New ProControl worldsound73 ProControl, Control|24, Command|8 28 03-29-2004 04:32 PM
DIGI 001 and Motu 2048 MK II or Motu 24i+ Logic Audio cyril 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-19-2002 09:08 PM
HUI or ProControl djf Pro Tools TDM Systems (Win) 0 02-23-2000 12:10 AM
ProControl & NT Camilo Orozco Pro Tools TDM Systems (Win) 4 02-16-2000 07:06 AM
