Old 11-21-2008, 02:04 PM
DrFord's Avatar
DrFord DrFord is offline
Default how do I get that daft punk vocal sound
anybody know what gear specifically they use for vocal treatments on songs such as "harder better faster stronger?"
thx in advance
DRFord
Homepage | Facebook | YouTube
Mac OSX 10.12.6 | Mac Pro 5,1 | 12core 3.46ghz
Avid HD Native PCIe Core | Pro Tools HD 2018.1
Old 11-21-2008, 02:58 PM
rockridge's Avatar
rockridge rockridge is offline
Default Re: how do I get that daft punk vocal sound
Here are some detailed instructions!
http://www.youtube.com/watch?v=K2cYWfq--Nw
Just kidding... use Autotune or Melodyne maxed out!
And edit the hell out the vocal...
Maybe a vocoder?
Old 11-21-2008, 03:07 PM
BaileyBass BaileyBass is offline
hahahah.. that is great.
Old 11-22-2008, 01:54 AM
PastaViking II PastaViking II is offline
Daft Punk has a large collection of vintage gear. I guess the vocal sound on "Harder.." is a sampled 70's vox box. See here: http://www.totonetwork.com/node/15794111
In any case the sound is very similar to the one used by Dr. Dre on "California Love" http://videokeman.com/2pac_tupac_sha...-tupac-shakur/
Old 11-22-2008, 10:00 PM
digilogin digilogin is offline
Banned
hello,
yeah, sounds like lots of vocoder. can't go wrong with robot people. very cool.
digilom
Last edited by digilogin; 11-23-2008 at 07:38 PM. Reason: digilom lurnz spellin of wurds
Old 11-23-2008, 01:48 PM
spiritG spiritG is offline
Word is that it is a talkbox modulating a synth, and there is a subculture about which synth to use etc. It evidnetly is a skill and not just "put a plug on it" evidently. It takes some experience as to where to place the tube and how to move the mouth to get optimum results.
It will be interesting to see what the talkbox plugin announced for PT8 will do. What will be the modulating signal? Did they model the properties of the amplified plastic tube a real talk box uses? And differing models of performers mouths (Let's use the Peter Frampton model because the Joe Walsh is too gritty?). Or will they supply a tube with it you use?
If they really successfully modeled how a real talk box works this alone could be worth the price of admission to PT 8 (some of the other features that many rave about might mean nothing to others- like the pitch feature to someone who has melodyne might not justify the hassle of dealing with Leopard when you have NI Vi's for example).
Old 11-23-2008, 02:49 PM
chrisdee's Avatar
chrisdee chrisdee is offline
I doubt PT8 comes with a tube. It would be very nice if it's possible to insert it on a track/aux and use the mic as "the tube" and play the notes with the guitar or with some of the sounds from the VI plugins in PT8 to get talking guitars and synths effects. Like the Roger Troutman or Peter Frampton effect.
But I'm guessing this wount be possible.
Old 11-23-2008, 04:02 PM
The plastic tube reference was a bit facetious. But the idea of modeling the resonances of different mouths that will go to the microphone and being able to apply those like a microphone modeler to modulate a source like a synth or guitar seems feasible if someone wants to put enough work into.
Probably initially they would be only very approximate and only usable in some instances, but eventually Waves would license Peter Framptons mouth and introduce the PF TALKBOX plugin.
Maybe if there is enough interest (read profit potential)-
This sound has been being used a lot in the last few years and not immediately accesible to most people because of the learning required to get optimum results from a talkbox.
Old 11-23-2008, 05:48 PM
Carl Kolchak Carl Kolchak is offline
Ha! I can see the relief on those hard up dental practices who can finally scrape the alginate off those porn stars organs and cavities they've been modeling, and start pouring it over rock stars oral cavities (and Hammond organs I suppose) .
You could get a "talkbox" of sorts with the old Emu samplers over 14 years ago by running a vocal through the vocal formant filter and assigning the cavity size (if I remember correctly) to the mod wheel on your controller.
You then just played the virtual mouth with the mod wheel. So it shouldn't be too hard to achieve nowadays, remember Delay Lama? :
http://www.audionerdz.com/
Cheers!
Old 11-23-2008, 06:43 PM
Andre Knecht Andre Knecht is offline
Originally Posted by digilogin View Post
[…] yeah, sounds like lots of vocorder. …
Word is that it is a talkbox modulating a synth, and there is a subculture about which synth to use etc. […]
It’s clearly a vocoder (not “vocorder”) and clearly not a talkbox.
In this particular case, the carrier signal is that of a polyphonic synth (played with a keyboard or MIDIed) as becomes evident towards the end of the song, where the lead vocal part transitions from its simple and rigid form to the more expressive form, replete with all sorts of classic bluesy keyboard licks. In a few spots, the carrier exhibits obvious LFO modulation and two-note intervals pop in, here and there.
What makes this lead vocal so interesting is the choice of modulator (the source of the vocal articulation), which isn’t immediately obvious, unless you do this kind of thing on a regular basis. It’s a computer speech synthesizer. After recording the speech synth “reading” the text (lyrics), some extensive work went into conforming the vocal part to fit the track rhythmically.
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Daft punk robot voices Raoul23 Tips & Tricks 9 06-27-2013 04:47 PM
Synth design by daft punk for tron questions DrFord General Discussion 1 12-31-2010 08:51 AM
ADC - Maybe a daft question paulrgmusic Pro Tools 9 8 11-07-2010 01:25 PM
Anyone know Daft Punk's kit list? tommydee General Discussion 0 11-09-2002 08:58 PM
RTAS filter plug ins? daft punk/fatboy slim Dopamine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 11-28-2000 10:58 AM
