Re: Techie Geek Question
Watkinson, not Atkinson! exactly right.
As for the frequency response, the theoretical response of a 192 kHz signal does go up to 96 kHz, bedfore aliasing occurs. The Digi specs state 20 kHz. Either that is an accurate value and the limiting factor is some component other than the converter, or it's simply a given value that was written in the spec sheet off the top of someone's head (a very popular practice, it seems). It probably isn't another filter in the converter. Having a gentle, high filter and then placing a brickwall filter at 20kHz would make absolutely no sense. There would be absolutely zero benefit to higher sample-rates. I have a hunch that filtering would be done in the output stages anyways. A Digi techie clearing this up would be nice. |
Can you help with some basic questions from a non techie? | rosiegsm | macOS | 6 | 04-21-2011 08:17 AM |
Techie Question - Virtual Machine | me beginner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 06-30-2010 05:33 PM |
Very simple question from non-techie Mbox2 user | SessionSinger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-05-2007 01:49 AM |
How to know if you are a geek:) | graveleye | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 21 | 04-13-2004 04:22 AM |
Techie Question!! | roijin | Pro Tools TDM Systems (Mac) | 0 | 09-05-2001 11:25 PM |
