Using 2 Compressors in the VOX chain
I have a distressor and LA2A. I wanted to go into the distressor and then into the LA2A. An engineer once told me that the first compressor would do the initial compression and then 2nd compressor would just smooth things out. So could anybody offer their 2 compressor techniques?
Re: Using 2 Compressors in the VOX chain
Like anything just try for yourself, although I normally go harder on the first then the second one.
I'd reverse that for most cases myself, but that's just me. The LA2A is the preferred vocal comp in most cases and the distressor would just add some fuzzy goodness.
J.Ho |
I'll sometimes use a compressor and a limiter. Set the compressor to a slow attack and release...then use the limiter to keep the fast transients in check. It can make the lead vocal very consistant. Although, most of the time it takes the life out of the track...but hey, if that's the sound the producer wants...then that's the sound the producer gets! LOL
Usually I like just using an LA2A and then doing volume rides/automation to fix anything that seriously jumps out or gets lost.
Derek Jones Sound Engineer / Producer / Composer Derek Jones Linkedin Megatrax Recording Studios Megatrax Studios Yelp Page A-list Music Artist Page |
I always preferred LA3a's on Vocals and I actually used to use 2 of them at the same time.
I'd set them pretty much the same. Perfect for really dynamic singers who don't know when to back off the mic.
Pro Tools Tutorials: Mixing Heavy Rock & Metal Pro Tools 11 - Tips and Tricks Delay Explained Tracking Rock - Drums Mixing Rock Music Production with Pro Tools Pro Tools Tips and Tricks Vol. 2 Pro Tools Tips and Tricks Vol. 3 Elastic Audio in Action |
yeah I agree with that. I like using an LA3A too...whatever's available at the time. But either is a good choice.
if you need to smooth out dialogue for vocals, try dup'ing the vocal track, shift it a few millisecs forward in time. Set the output of the dup'd track to an unused buss. Then put a compressor on the original track. Set the compressors key input to the bus your using for the dup'd track. The compressor will act before you actually need it. allowing you to select a softer attack and still get those pesky bumps.
Look-ahead kind of comnpressor.... cheers georgia
georgia hilton CAS MPSE MPE Hilton Media Management Film Doctors http://www.filmdoctors.com Me... http://georgiahilton.webs.com/ Stage 32 http://www.stage32.com/profile/6569/georgia-hilton My Production Company http://www.hiltonmm.com CREDITS (partial) http://www.imdb.com/name/nm0385255/resume MEMBER: IATSE LOCAL 700 |
Interesting concept Georgia, I've gotta try it.
georgia, That is the coolest tip I've read in a long time! Got to try it.
Peter |
Firewire -- to chain or not to chain | DJMike | Storage Subsystems | 3 | 02-23-2009 08:40 AM |
URS Compressors | Third Eye Studios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-07-2005 11:09 AM |
Talkback - Side Chain, Gates and compressors | Jburn34 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-11-2004 04:39 PM |
what compressors do you use for vox? | shaun thomas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 28 | 09-06-2003 07:43 PM |
studio setup - midi - to "daisy chain" or not to daisy chain - do I want a multiport | Joseph Anderson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-24-2002 02:45 PM |
