Can you run your computers sound thru the 002?
i'm not sure if its possible but can you setup your computer so that all sound like itunes and quicktime will run through your 002? if so how do you do it?
thanks |
Re: Can you run your computers sound thru the 002?
easy solution is to just take your audio out from your computer and run it into the Alternate monitor input on your digi002.
Use the Digi CoreAudio setup
He used to cut the grass...he was a very nice boy... |
everything but the system sounds.
You can run sounds only on an application by application basis by entering them into Core Audio's Preferences.
Systems Sounds are explicitely excluded. |
Do you have the core audio driver installed?
i'm assuming you mean the 6.1.2 driver? i just downloaded and will be able to install it tomorrow, all my gear is at my friends cuz i dont have room at home. once i do have it in where do i go to set the core audio preferences?
J.Ho |
word. thanks i'll do that tonight.
Using 2 computers | padraic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-20-2009 05:56 PM |
PT8.0 Computers? | Mix Master Factories | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 04-18-2009 09:51 AM |
Using two computers. | chicoman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-14-2006 04:09 PM |
OT: Sound Isolation for Loud Computers | Sabin Recording | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-07-2003 01:02 PM |
Sound Designer on Atari Computers | Badger | Digidesign Hardware & Software | 0 | 09-14-1998 12:58 AM |
