Windows 7 better stability with HD than XP?
Just curious to know if anyone has seen increased stability with HD on Win7 with PT9 as opposed to 8.1 on XP? Pretty much the only reason we would consider upgrading since increased functionality between the versions is minimal. You know, less Access Violations and RTAS/VI memory related issues. Our HD6 XP system with Magma Chassis is quite usable and pretty stable but, there are annoying issues that we've always had to workaround with various Digi approved computers on XP. Thanks...
Re: Windows 7 better stability with HD than XP?
I have found win7x64 alot more stable than XP.
Go out, buy a new HD and install win7x64 and Protoools 9 on it. Keep the XP hard drive in your drawer. You will always have a backup in that case. cya Ghengis
Intel I7-930 Asus P6T-Deluxe V2 6gig Triple Channel 1600mhz HD2 PCI, 96 I/O, Command-8 Win7x64 |
Thanks for the reply.. Yeah, we would have to get a new computer to run Win7 - especially if we go 64 bit (diff processor/motherboard would be needed). If stability is better, it'd be well worth the investment and the time in doing the fresh install.
Thanks again. Anyone else feel free to chime in. Much appreciated. |
Wow! Only 1 reply? haha.. Nobody has experience with HD on XP and then went to Win7? I guess we'll sit tight for a bit!
You dont want to wait, go ahead and upgrade, W7 64-bit is awesome, after trying it a while ago there's no going back for me.
Alright then.. That was an emphatic YES... Thx!
Agreed. Home system: 9.0.2, HD|2 Accel, HP xw8400, 2x x5355, 8GB, now on Win 7 x64 Pro, not looking back
Put it this way, if you want to go to 9, you have to go to Windows 7. No other supported option.
cya Ghegnis
Windows 7 64 bit is a huge step up from XP in my opinion. For the memory alone!! Also, Pro Tools has never run better!!
https://www.thirdeyerecording.com/ |
Thanks guys. The only reason we are considering the upgrade to PT9, Genghis, is to take advantage of the potential extra stability of Win7 (not the other way around) since they are now officially approving Win7 for HD (we like to wait for 'official' approval!! - even though we know many guys have been using Win7 with PT8 and having positive results). So, again, thanks for all of the input. It looks like a go from here!!
Windows HD Stability | stanonbass | Pro Tools TDM Systems (Win) | 5 | 03-11-2007 10:51 PM |
Running LE 6.1 on Windows XP.... stability problem | digifart | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-28-2003 03:28 AM |
Windows ME Stability | fresh_meat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 38 | 07-31-2002 07:03 PM |
Stability | nny | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-16-2001 01:12 PM |
G4 500 with PT 5.0.1 Stability? | cander | Pro Tools TDM Systems (Mac) | 5 | 10-01-2000 06:55 PM |
