Old 08-20-2006, 02:14 PM
Strantz Strantz is offline
Default Problem Bouncing Song...
Hey guys,
When I attempt to bounce a song, i get this error:
Cannot compelte Bounce to Disk commande due to assertion n "FF_AudioProperty.cpp", line33.
Any ideas,
THanks alot
Aaron
Old 08-21-2006, 09:04 AM
req06 req06 is offline
Default Re: Problem Bouncing Song...
try the general troubleshooting tips sticky at the top of the duc. delete prefs etc.
should solve it.
try submixing to take load off cpu maybe? like get the mix sounding nice then deactivate all traks apart from drums the nbounce a stereo drum wav, do the same for each set of instruments, vox, bass, keys etc. leaving you with stems of the collapsed mix.
should alleviate pressure on yr cpu
G5 dp 2.0Ghz, 2.5 gb RAM/ G4 Powerbook 15" 1.33mhz, 2gb RAM/ 002r/Lacie D2 FW800/PTLE 7.4
Old 08-21-2006, 11:35 AM
LaForestPoetry18 LaForestPoetry18 is offline
Increase your buffer size, depending on what KHz you are at (41.1, 48, 96), then you have to increase your buffer size, CPU Usage Limt and DAE Playback Buffer. This is the only solution that I know that actually works time after time. Then after a while you will automatically know what setting you need to have ahead of time. I hope that this helped.
La Forest Gray
Unleashed Entertainment, Inc.
Exc. Producer
Bouncing song for use on another program? like Logic? jimbojimbo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-05-2007 02:10 AM
How do I trim or truncate a song before Bouncing autonickv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-15-2006 11:14 PM
Speeding up a song while bouncing to disk Moxon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-09-2005 02:19 PM
bouncing song with reason... gregor rasek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-11-2004 03:16 PM
Help with bouncing my song to file to be burned trope75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-20-2002 09:00 AM
