Old 05-31-2023, 11:26 AM
Ben Jenssen's Avatar
Default Any way to 'spill' routing folder on Artist Mix?
Even though I have been using Command 8 and Artist Mix and Control app the last few years, I have only bothered to learn things as I needed the functions, so I still have many blanks.
I know I can use Control app to spill/unspill folder tracks and VCA's, I would love it if I could do it on the control surface and not ipad or mac.
(If someone has a tip for quick access to Eucon functions and features, I'd very much welcome it. Between reading the manual and watching youtube videos, I'd like to have something quicker, more condensed, if it exists.)
Old 05-31-2023, 11:40 AM
its2loud its2loud is offline
Default Re: Any way to 'spill' routing folder on Artist Mix?
The spill on the Artist Mix should work the same as the S1. Double tap on the Sel button on Artist Mix and the Folder will spill.
Old 05-31-2023, 11:43 AM
Thanks. I just found it, in a PTE article. It's about S1, but it works on Artist Mix too.
Routing Folder Inside Routine Folder - Solo Issue John9281 Pro Tools 3 03-20-2022 10:43 PM
S1 VCA/Folder spill then unspilling to previous VCA/Folder layer frankuswalker Avid S1, S3, Dock and Control App 2 02-25-2022 09:26 AM
Folder “spill” is not yet implemented Maro Records Avid S1, S3, Dock and Control App 11 09-09-2020 07:47 PM
Spill Folder Tracks Nico Berthold Avid S4/S6 7 04-28-2020 04:35 AM
Another Folder Track bug: Soloing a Routing Folder doesn't solo routing bus XJENSEN Pro Tools 2020 7 04-24-2020 07:29 AM
