Old 02-01-2023, 01:56 PM
KenSluiter's Avatar
KenSluiter KenSluiter is offline
Default Re: footswitch not working
sure. Need your e-mail. you can send to [email protected]
Old 02-01-2023, 02:12 PM
KenSluiter's Avatar
this should work.
https://we.tl/t-BVSPGhXpjh?utm_campa...trk=TRN_TDL_05
Old 02-01-2023, 03:43 PM
EddieJones's Avatar
Got them thanks...will report back if we find something
Old 02-03-2023, 08:25 AM
EddieJones's Avatar
The logs don't help unfortunately. As it is working here on these Mixes I wonder if it's a hardware issue.
Old 02-03-2023, 08:54 AM
KenSluiter's Avatar
could it be firmware?
  #16
Old 02-03-2023, 09:03 AM
EddieJones's Avatar
Unlikely.....but you can easily check on the surfaces tab
  #17
Old 02-03-2023, 11:14 AM
KenSluiter's Avatar
do you know what would be involved in getting repaired?
  #18
Old 02-03-2023, 12:04 PM
EddieJones's Avatar
If this is the later Avid Mix then it can still be sent in for repair.....but I'm not sure it will be worth it as the cost might be close to its value on eBay, if not higher when you factor in postage.
  #19
Old 02-04-2023, 07:23 AM
Neale Neale is offline
My Artist Control was plug and play. You can test it in the EUCON prefs control panel. While the status may not pop up immediately (it doesn’t for me, Eddie, even on my S1 and newest EUCON), once you trigger the switch it should indicate if the software is seeing it as open or closed.
If you still don’t see anything, the Artist Control isn’t too bad to crack open, you just need to be careful with the very thin and flimsy metal shielding inside the casing. You likely won’t have to mess with the screen but careful with that, as the frame is a PITA to reassemble properly. If you’re handy enough, or if your tech is comfortable with it, it should be a really simple exercise to test the hardware (electrical circuit) part of it. I would have to imagine that as long as the jack is solidly connected to the board with no shorts, the software part will “just work”. And then if the jack is pooched somehow, I imagine it would be pretty simple to get a PCB-mounted jack from Mouser or Digikey, remove the old from the board, throw the new one in. Parts cost maybe $10, plus some elbow grease, and you’re good to go.
Footswitch Stopped Working With Mbox Pro Kickdrum60 Pro Tools 11 2 05-02-2017 05:06 AM
Footswitch not working Mbox Pro 2 - Pro Tools 10 gbross Windows 2 03-27-2013 04:11 PM
Footswitch stopped working on 003? DWAGS1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 10-17-2011 04:01 PM
Footswitch has stopped working. MrChrisos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-05-2009 06:23 AM
Footswitch Pe-sound VENUE Live Sound Systems 7 01-12-2009 12:03 PM
