playing different regions at half speed?
I know you can play an entire seesion in half speed mode by pressing {shift} + {spacebar}
But is it possible to play different tracks at different speeds simultaneously? Using the 'sample editor' perhaps? Where is the sample editor located? |
Re: playing different regions at half speed?
Since the rate at which PT plays is dependent on the sample rate hence clocking speed of the session, all regions you play in a given session are going to play at the same 1/2 1 or 2X speed (or more or less if you have a TDM system). Obviously you CAN change the speed of a given region by processing, otherwise no.
Xray |
Have you tried moving from sample-based tracks to tick-based tracks and then programming the tempo track the way you like? I'm not sure it works, but in theory it could. If it doesn't work or fit into your situation, then, just sacrifice some audio quality and do the time-stretch
Pitch yes, but speed no - it's impossible to play a region before it's happened! You have to change each track separately and then play back it all together to hear the result.
Mac Computers/PT12/Lots Of Lacie D2s |
Distortion when playing back audio at half speed | midnightrambler | Pro Tools HDX & HD Native Systems (Mac) | 0 | 12-07-2013 09:20 AM |
Noise when playing back at half speed. | Polarbear066 | Pro Tools 11 | 9 | 09-30-2013 09:28 PM |
playing different regions at half speed? | thechakras | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-05-2006 02:45 AM |
PLAYING A WAV FILE AT HALF SPEED | digimike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-10-2006 12:04 PM |
shortcuts for half speed +dbl speed recoring | neatguys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-09-2003 02:48 PM |
