Old 12-07-2011, 04:24 PM
Thuneau Thuneau is offline
Default HD I/O Strange behavior
I'm in process of setting up an HD3 system with three HD I/O interfaces. I have a total of 5 AD cards, 4 DA cards and 2 AES cards. In I/O setup I can see all 40 analog inputs and all 32 analog outputs. They are all enabled. But when I go to record enable a track and select the input for it, I only have the choice of the first 32 analog inputs.
The interfaces are plugged in in the following order:
HD Core> HD I/O#1 (1x AD card)
HD Accel 1 > HD I/O#2 (2x AD card) >HD I/O#3 (2x AD cards)
HD Accel 2> no interface hooked up
I don't have a third long digilink cable so that's why I daisy chain two interfaces off one HD Accel card. But even so, I only set up 32 inputs on that cable and the first 8 inputs on HD I/O#3 work fine.
Any ideas as to why the second bank of inputs on HD I/O#3 can't be selected as source for recording even though it is visible to Pro Tools in I/O Setup dialog?
Old 12-09-2011, 03:01 PM
Ginger Ginger is offline
Default Re: HD I/O Strange behavior
Is it also visible correctly in Hardware Setup?
I would not set this up this way.
If it were me, I would go:
HD Core> HD I/O#2 (2x AD card) >HD I/O#3 (2x AD cards)
HD Accel 1 > HD I/O#1 (1x AD card)
The way you have it hooked up is a little weird. I can't promise you this will solve your problem, but I would start there.
Strange Behavior Bender 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-16-2007 04:19 AM
FB strange behavior Branko Post - Surround - Video 2 11-26-2006 04:35 PM
what about this strange behavior? AuraMaris Studio Pro Tools TDM Systems (Mac) 4 10-25-2004 02:11 PM
Mac OS strange behavior mixaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 05-20-2003 08:42 AM
Strange PT behavior agus Pro Tools TDM Systems (Mac) 0 10-26-2000 10:27 AM
