Old 08-11-2004, 02:34 PM
bgbari bgbari is offline
Default Headphone Mixes
I have the digi 002 and want to create 4 seperate headphone mixes. In other words each guy has control of what he wants to hear. (Drummers always want more of themselves and less vocals) Is this possible without purchasing a ton of equipment? If not, what do I nedd?
Thanks for the help!!
Brandon
Old 08-11-2004, 03:51 PM
Chris Cavell Chris Cavell is offline
Default Re: Headphone Mixes
You need 4 headphone amps and 4 sets of headphones and the cables to go from the 002 line outs to each. Use aux sends to hardware outputs. You have five sends per track, so you can create up to five seperate headphone mixes that way. You could also create 4 aux inputs for each instrument and send each one to a different set of hardware outs...but that would cause quite a large mixer to navigate about.
Cavell Studios
Old 08-11-2004, 04:36 PM
Matt Whritenour Matt Whritenour is offline
i would recomend the behringer powerplay pro headphone amp
then after u set up ur aux sends in pro tools u can send it out
of a hardware output on the 002 then patch that into the direct input
of the headphone amp. and when u come out of the 002 u can either use a stereo
aux send or mono if u use stereo its gonna use more of ur hardware outputs and u would
need insert cables so u have a stereo signal or u can just do it mono and use 1 output of the
002 and into the direct in put of the headphone amp then press the Mute Right button and the
Mono button...
www.klarityrecordingstudios.com
Old 08-12-2004, 09:14 AM
wertt wertt is offline
i'm doing this with the oz audio hm-6. you can buy it online at riks music for $260 (they also carry it at sweetwater, etc). i have outputs 2-6 running into the matrix which allow for 6 different headphone mixes. i can run protools le with my hardware buffer at 64 samples, which works quite well. this was by far the cheapest and easiest solution i could come up with.
Old 08-15-2004, 08:25 PM
The Behringer HA4700 has 4 sections so you can use it for 4 mixes. You can also dump a stereo mix into all the sections and send 4 outs from your 002 into the 4 sections so each player can have "more me" on top of the main mix if you like.
Old 08-17-2004, 02:18 PM
jvk jvk is offline
how do you deal with soloing tracks in pro tools without effecting the headphone mixes?
jvk
jvk
Old 08-17-2004, 03:34 PM
jvk
because you would set the Aux Sends to Pre Fader
Old 08-17-2004, 03:49 PM
cybership cybership is offline
This is the textbook method to set up a headphone cue however it will not work for PT LE if you need low latency monitoring.
Old 08-20-2004, 07:15 AM
Straatocastoer Straatocastoer is offline
I personally own and recommend the Furman HDS-6 system. Should fill all of your requirements.
-Stan-
CrossFire Studios
Old 08-21-2004, 05:53 AM
katoramone katoramone is offline
Your furman link wont load BTW. but they are nice, i know then and not too costly...but i use the behringer...its fine. Actually the aux ins per channel make for neat blending tricks.
headphone mixes in pt hd joeymusicguy Tips & Tricks 7 03-26-2010 07:00 PM
Headphone mixes; how to toddbux General Discussion 5 09-23-2009 02:47 PM
Headphone mixes paul_g 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-09-2008 09:56 AM
HEADPHONE MIXES SWC Pro Tools TDM Systems (Mac) 3 10-31-2003 04:31 PM
Headphone Mixes Punx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-18-2002 04:07 AM
