Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 10-15-2002, 07:52 PM
citysoundman citysoundman is offline
Default Disk Doctor vs. Disk Warrior??
I'm a long standing Norton Disk Doctor user. Lately I've noticed many Pro Tools users, and all Avids, using Disk Warrior. A while back Avid switched delivering their systems with DD to DW. What are the differences?
Also, when using Disk Warrior, should I enable "protection" (I think that's what it is called). It is some kind of extension that checks hard drives. My thought is it might interfere with Pro Tools.
How do most DW users use DW?
Bob Kirschner
Chief Engineer
Creative Media Design, NYC
http://cmdnyc.com
bob@cmdnyc.com
Old 10-15-2002, 10:25 PM
DesertDude DesertDude is offline
Default Re: Disk Doctor vs. Disk Warrior??
Boot from the DW CD, run disk warrior then run the optimizer forget all the automated stuff, or loading it on the computer. better yet get your mac running as best you can then save the whole HD on to another drive. when you have a problem, save the important files, then zero out the fragged HD and copy the saved HD back onto your main drive. saves time ( or run DW while you sleep) [img]images/icons/wink.gif[/img]
[img]images/icons/cool.gif[/img]
DesertDude
1.25 Alu/1.5 ram/10.3.4
PTLE 6.4-002R-Live-Reason
Old 10-15-2002, 10:28 PM
more info here
DesertDude
Old 10-16-2002, 06:39 AM
Desert dude:
So you use DW for regular optimizing? Do you need to boot from the DW disk just to optimize? And are you talking about internal HD, PT drives, or both - are the optimizing procedures different?
Bob Kirschner
Chief Engineer
http://cmdnyc.com
bob@cmdnyc.com
where02190 where02190 is offline
If you have drive space to copy all your audio files to another dirve, it is much faster and the most efficient and complete defraging to simply use the Apple drive set-up utility and reinitialize the drive. this takes less than 5 minutes.
If not, then runninng DW and PlusOptimizer from disc with no protection enabled is the recommended method.
Hope this is helpful.
Old 10-16-2002, 07:04 AM
RobMacki RobMacki is offline
I've been using Disc Doctor then Speed Disc for over 5 years.
How is DW better to use than DD/SD?
Old 10-16-2002, 08:12 AM
citysoundman...
Desert dude:
<font size="2" face="Verdana, Arial">yes, yes, yes & no DW seems to do a better job at optimizing and not screwing up anything. it just takes a while to do. Wheres suggestion is faster and cleaner [img]images/icons/wink.gif[/img]
DesertDude
Old 10-16-2002, 08:54 AM
bassmac bassmac is offline
I use DW and Norton Speed Disc on my boot drive. On my audio drives, I just back-up and reinitialize everything - it seems safer, and more efficient.
Old 10-16-2002, 05:26 PM
I don't knwo anyone who has ever lost a file to DW. I know several who have to DD.
using disk doctor yes or no? ohmy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-15-2007 02:20 AM
HELP with disk Warrior Mark Haliday Pro Tools TDM Systems (Mac) 3 07-25-2003 08:21 AM
q: about Disk Warrior pk_hat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 07-14-2003 07:28 PM
Disk Warrior BMI Studio B 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-02-2003 06:10 AM
Disk Warrior? flymax Pro Tools TDM Systems (Mac) 2 12-04-2001 07:51 AM
